Old 05-24-2006, 07:00 PM
*Registered User*
coolman is on a distinguished road
T-Slot tables
Where can I buy the T-Slot aluminum extrusion that can be used to build the CNC work table where your raw material to be milled can be clamped down? I am not interested in using the regular aluminum extrusion where the coolant liquid can leak from the table down to the floor. This part should have the feature to prevent the coolant from leaking down to the floor. I have seen several pics of this type of extrusion but cannot find a source where to buy them.
Old 05-24-2006, 07:35 PM
ger21's Avatar
Contact this guy. He's a member here. http://cgi.ebay.com/T-SLOT-Plate-13x...QQcmdZViewItem
Old 05-25-2006, 02:15 PM
*Registered User*
Thanks for the ebay link.
Are there other sources for t-Slot type tables?
Old 05-26-2006, 01:30 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
The other possibility is to buy an x/y table and cannibalize it. That's what Swede (5Bears) did to build his mill:
http://www.5bears.com/cnc09.htm
BTW, the fellow on ebay is Widgitmaster and here is his thread about making these tables:
http://www.cnczone.com/forums/showth...t=widgitmaster
He's working pretty hard for his money. I doubt you'll do better than to just buy one of his tables off eBay.
Best,
BW
