Old 04-25-2006, 05:03 AM
tivoidethuong is on a distinguished road
How many hp i need to cut steel?
Hi! I want use AC 3 phase motor control by VFD. How many hp i need to cut steel?
Old 04-25-2006, 05:45 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Sorry, you haven't provided enough information for anyone to give you a meaningful answer. What size tooling do you intend to use to make what size parts in what steel?
Regards,
Mark
www.wrathall.com
Old 04-25-2006, 06:04 AM
*Registered*
lakeside is on a distinguished road
also your spindle speed will need to be very low rpm
Old 04-25-2006, 06:53 AM
Thanks for your reply
i want build spindle sames Tormach PCNC 1100. Any have it. Take some pic of spindle motor.
Old 04-25-2006, 07:32 AM
dkowalcz's Avatar
dkowalcz is on a distinguished road
Rule of thumb for steel is 1 hp per cubic inch removed per minute.
Be aware that the shaft hp for a VFD controlled motor is only valid at the full load speed of the motor or above (1800 rpm or whatever). Less than that, and it's basically constant torque only.
Old 04-25-2006, 07:47 AM
Mcgyver is on a distinguished road
like dk said, power equates to removal rates and changes by material. a child can remove steel by hand (say with a file or engraver) so its not that its steel that is the constraint, its how fast you want to remove it. careful though, you can't scale the above rule of thumb or quickly the rest of the machine (rigidity) won't keep up!
Old 04-25-2006, 08:07 AM
my CNC machine speed max is 800mm per min, too slow uhu?
Old 04-25-2006, 08:21 AM
thanks you. I know that power equates to removal rates and changes by material . But i want my machine can cut steel, or alium. I don't know how many RMP motor 3 phase can run?
Old 04-25-2006, 09:01 AM
NC Cams is on a distinguished road
Please provide more specific information as follows:
What thickness steel???
Full face cut (plunge) or simple light facing???
What grade of steel???
How hard is steel???
What size cutter (diameter) do you plan to use???
How many flutes???
What is cutter material???
How fast in ft/min or mm/min do you wish to cut???
These are just starter questions. If you don't know spindle size, thus bearing sizes, you may not have capacity/rigidity to do real heavy cutting.
Care to start over????
By the way, generally speaking, typical spindle motors for mills run from 1.5 to 2.5hp and some as large as 4-5hp.
If you can't answer quesions in sufficient detail, use about 2.5hp as a decent, "fits all" starting point. This much power should cut whatever you want to cut....
Old 04-25-2006, 10:46 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I concur. You could get by with 1HP but 2HP would be more capable.
Scott
Consistency is a good thing....unless you're consistently an idiot.
  #11   Ban this user!
Old 04-25-2006, 08:43 PM
i want mill part same part on the background of www.bobcad.com.
May i connect direct moto saft to spindle saft or use belt?
  #12   Ban this user!
Old 04-25-2006, 08:59 PM
some pic of part i preprair for my machine
