Old 04-02-2006, 06:00 PM
phantomcow2 is on a distinguished road
Bosch 1617EVS
Well I was looking at the BOsch Palm router (Colt) for my machine, but I am doubting if 1HP will suffice for my needs. I just think that for a little extra $, I will be much happier. I fear that I will not be able to use a large enough endmill to take off enough material fast enough as I want.
So my sights have been redirected toward the Bosch 1617EVS, this is 2.25HP variable speed. 2.25HP seems a lot more like what I want. I may not always need 2.25HP, but I want to have it just incase the day does come.
So what are peoples experiences/comments with this?
Old 04-02-2006, 08:56 PM
Madclicker is on a distinguished road
I'm leaning strongly toword the Hitachi M12VC. Can't find a single negative on this router.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 04-02-2006, 09:03 PM
Oh wow, that looks like a fantastic router. i am looking for reviews now...
The price is right for sure!
Old 04-02-2006, 09:44 PM
HayTay's Avatar
HayTay is on a distinguished road
Do a search on CNCZone for M12VC and read the reviews/posts. I'm using one, so is Joe2000che, WarrenW, LionClaw, & CarlnPA. Probably others too. Fantastic router for $114.00. It has a nice straight body for mounting in a bracket after removing the base.
HayTay
ID:	16343   Click image for larger version
ID:	16344   Click image for larger version
ID:	16345   Click image for larger version
HayTay
Don't be the one that stands in the way of your success!
Old 04-02-2006, 09:55 PM
tinygiants is on a distinguished road
I have the Bosch Router. In fact, I have 2. I have one mounted in my router table. The other I use free hand with a fixed base and a plunge base. I love the fact that it has the dual collet for 1/4 and 1/2" bits.
Dale
Old 04-02-2006, 10:13 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Stick with this size, you will appreaciate it. I have a factory rebuilt 1617EVS and find it a very professional, quiet machine (They were having trouble with the on/off switch which they fixed). There were a bunch of the rebuilts available a few months back for around $120, they seem to have jumped to $160. Like here. One complaint I have with the Bosch is the fan blows down, and if you don't have a vaccum skirt around the bit, a lot of dust will be airborne.
This Hitachi does seem like a good bang per buck.
Steve
Old 04-02-2006, 10:20 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
HayTay
The router works great for me. BTW i like the mounting brackets
Joe
Old 04-02-2006, 10:34 PM
Wouldn't the fan blowing down be a good thing? If it didn't it would suck crap up from the cut to the inside of the router? I think they all blow down. It's why you should set your dust collection port on the side rather than the bottom of a stationary router table. Sucking from the bottom tends to negate air flow through the router. I burned up one several months ago and I'm sure this was the reason. Lucky it was still in warranty. Which is another plus of the Hitachi....5 year warranty.
Steve
Old 04-03-2006, 05:37 AM
Ugh, I have to say, they both seem to have some positive reviews. I was looking at the refurb Bosch on ebay as well, so they are both about the same price. The best price I've found on the Hitachi is 128 dollars.
The 5 year warranty is nice though...
What about noise? Anybody know which is quieter?
Old 04-03-2006, 08:12 AM
spalm's Avatar
Gold Member
I just saw the refurb Bosch on Amazon for $125. Always hard to recommend something, incase you are disappointed.
Yes I agree that blowing down is preferred to sucking up. It just seems like the Bosch blows down quite aggressively. I’m just throwing out some observations. The magnesium base, collet, and bearings seem top notch. (And I love those wood handles that you will only use if you use the router on its base.)
Steve
  #11   Ban this user!
Old 04-03-2006, 10:52 AM
bbergami is on a distinguished road
I've got 2 of the 1617EVS. They hold up well and they're quiet, especially if you are running at less than full speed.
  #12   Ban this user!
Old 04-03-2006, 11:43 AM
Bowman's Avatar
Bowman is on a distinguished road
Lowes is showing the Hitachi at $114.00 and with a 5 year warrantee I think I might try one of these myself. They say on the specs that it runs at 79dB which is fairly quiet. I like the built in variable speed control also that maintains constant RPM even under changing loads.
Now did they measure that amount of noise with a cutter cutting wood at full speed or the lowest speed no cutting I don't know. Does look like what I will go with though. Just got my 70" X axis rails on ebay so now I have all 3 axis's parts and can finally start to design the router itself.
