03-28-2006, 04:26 PM
 | Community Moderator | | Join Date: Mar 2003 Location: Shelby Twp, MI....USA
Originally Posted by cwdance1 I know that increasing the voltage increases the speed. But will the speed realy increase if I'm at the max output for the computer I'm using? |
Are you saying you're using 25,000 steps per second with 12V? Or 35 or 45Khz? With 1/8 microstepping and 200 step/rev motors, 25,000 steps per second can give you roughly 950 rpm. I doub't you're anywhere near that using 12V. And if you do reach the limit of 25,000 steps per second, you can change the settings in Mach to use 35,000 or 45,000 steps per second, provided your PC is fast enough.
Usually, your useable speed increases proportionally as you increase voltage. Double your voltage should double your speed.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
