Old 03-18-2006, 10:25 AM
russell is on a distinguished road
what is this
hi everyone
could someone tell me what this is
a power supply or a driver board?
thanks Russell
ID:	15722   Click image for larger version
Old 03-18-2006, 12:11 PM
b_cybe is on a distinguished road
There are atleast a power supply in there you can see that transformer that takes half of the space in the box. Then it seems like the transformer is connected to a rectifier to get DC out. The DC output from the rectifier is then (I think... a bit hard to see...) connected to a electrolytic condensator wich "flatten" the DC voltage. Allt these components are found in most power supply so that part is a power supply. After the condensator it is a bit difficult to se, if you tell me the name on the IC it might get clearer what this is...
Old 03-18-2006, 12:43 PM
Rance's Avatar
Rance is on a distinguished road
The first one is a blurry picture, the second one is a ReMax flyer. Next time you send a picture of a nice flyer like that, be sure to move that big power supply out of the way so you can get a better shot.
Old 03-18-2006, 02:37 PM
Al_The_Man's Avatar
It has all the appearance of a linear regulated power supply, Looks like one voltage out, they are made by PowerOne and a couple of others.
You can get the PDf here http://www.power-one.com/cgi-bin/acd...rodtype=linear
Old 03-18-2006, 04:27 PM
here are a couple more pictures
I'm trying to salvage as many parts as I can from my local scrapers, limited buget you know
is it possible to use this for my motors?
thanks guys
ID:	15732   Click image for larger version
Old 03-18-2006, 05:53 PM
2muchstuff is on a distinguished road
It's a 24 volt 4.8 amp regulated power supply.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
