Old 03-17-2006, 02:52 PM
SCCoupe is on a distinguished road
Anyone know where to get this exact type of servo motor?
Found elsewhere in this forum.....
The servo motors are 36VDC 430 oz/in peak. The peak amps is rated at 20. I just get a 36VDC 10-15 AMP power supply to run them. The encoder is 250 CPR which will translate to 5000 PPR when connected to a G320 drive. They will produce 1700 RPM and this is why I run them at a 2:1 ratio.
The size of the motors are 2.26 dia X 6.2 long including encoder. The staft is 1/4" dia as sticks out .750 long.
They are clasified as Nema 23 size. They don't have mounting brackets with them, they only have 4 6-32 hole on 1.531 B.C.
Anyone know where to get these?
Old 03-17-2006, 03:41 PM
bill south's Avatar
bill south is on a distinguished road
Hey Coupe
How are you getting 5000 ppr out of a 250 quad encoder with a g320. I replaced my 250's with a 500's just to get some resolution. Sounds like I wasted some $$$$. Are you in South Carolina???
Just curious!
billyjack
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 03-17-2006, 10:58 PM
Ok, I finally found a place that has them.
http://www.seanet.com/%7Edmauch/
I am just starting on this project and seen the stuff in my last post on this board and wanted the motors that it mentioned. So I do not yet get that kind of resolution because I am still building.
Thanks all!
