Old 03-16-2006, 03:56 AM
Max-DK is on a distinguished road
Threaded rod.
Hi guys.
I know a lot of you have used threaded rods, as a substitute for leadscrews. But has anyone tried to use stainles steel rods, and then polishing it for a smoother finnish. And then using either an delrin or nylon nut, for the axis movement. I would think that when polished, everything would run real smooth.
Regds
Max
Old 03-16-2006, 11:16 AM
jcc3inc is on a distinguished road
Sir,
Here is a source of acme threaded rod AND nuts.
Green Bay Mfg. Co., Box566, Two Rivers, WI 54241-0056, Ph 920-793-2411
I have not used them but they have consideraable variety.
Regards,
Jack C.
Old 03-16-2006, 11:47 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
Normal threaded rod actually works quite well for leadscrews.
Its primary failings are twofold...
First is surface finish which can be dealt with by polishing, or buying unplated rod.
Second is thread accuracy. Since it's not designed for precision applications, it's not made precisely.
There's actually a 3rd failing, too...the thread does not transmit power as efficiently as ACME or ballscrews. But, for small homebuilt routers, this is not so big a problem as it would seem.
Threaded rod also has some major strengths, like being cheap and available EVERYWHERE. It's also pretty darned good in quality, despite the occasional thread wander. I'm retrofitting a Chinese mill-vise, and replacing the absolutely horrid leadscrews with threaded rod. It's an "on the cheap" retrofit, and the threaded rods should be quite adequate.
-- Chuck Knight
Old 03-16-2006, 11:51 PM
ViperTX is on a distinguished road
Max-DK.....hmmmmm....you're going to polish a threaded rod.....boy that will be a labor of love.....sure it will work great....snicker...snicker......
Old 03-17-2006, 12:46 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Actually I have been making and selling 3/8-16 & Acme 1/2-10 rolled thread leadscrews with delrin nuts on eBay for months now!
http://search.ebay.com/_W0QQsassZeaaenterprisesQQhtZ-1
The problem with rolled threads is the metal flakes which get pressed flat while the metal is in the rolling process! The 316-stainless alloy is the best thread, as it forms better without flakes like steel! I have been buying bulk All-Thread from several places, looking for the straightest and cleanest threads!
After turning the ends, I occasionally run a piece of ScothhBright over the threads to remove the scales! But polishing is not necessary! You can also buy a "Machined thread" which is not rolled! Much higher price tho!
If you need smooth travel, NOOK rolled ball screws go for $1.25/inch +$25.00 for the ball nut. Turning the hardened ends is a bit tricky !
http://www.homeshopcnc.com/page2.html
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 03-17-2006, 01:41 AM
Thanks for the inputs. The reason i was asking, is that the Acme rods are not available here in Denmark. So i think i'm going for a standard threaded rod 14mm, as this will give me a resolution of 0,01mm/step. For my first machine this will be ok, later maybe real leadscrews.
Old 03-17-2006, 02:31 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
Standard threaded rod should work fine for a first machine. If you did want a better rod, you might try looking for Trapezoidal screws rather than Acme. Trapezoidal rods are designed for power transmission just like acme, but but have a slightly different profile, and use metric sizes, so might be available in Denmark. Here is som information about trapezoidal screws. http://www.roton.com/index.php?section=82&print_code=9
Old 03-17-2006, 07:31 AM
Jason Marsha is on a distinguished road
I have used stainless steel threaded rod as well as the standard one on my machine and the only difference I have seen between them is that the ss version is stronger, therefore it does not whip as easily as the standard version. There should be no need to polish ss threaded rod it as it comes with a very good finish already.
Jason
Old 03-29-2006, 02:22 PM
martinw is on a distinguished road
Hello Max,
jeffs555 is spot-on. DIN 103 trapezoidal spindles are available in Europe.
They are very nearly the same as ACME, but come in metric diameters. I have been agonising about whether to use DIN 103 or ACME. The problem in the UK is that although DIN 103 spindles are quite inexpensive (pitch accuracy 0.15mm per 300mm), I don't seem able to find simple nuts for shaft fixing etc. Anyway, a company in the UK called Huco have the stuff. Here is a list of their outlets in Denmark....
http://www.huco.com/distributors.asp
If you go ahead and find some cheap nuts to suit, I'd be really grateful if you could let me know.
Good luck
Martin
Old 03-29-2006, 03:18 PM
*Registered User*
Carel is on a distinguished road
Martin, you mean these nuts?
http://www.skf.com/portal/skf/home/p...ewlink=1_16_21
Carel
  #11   Ban this user!
Old 03-29-2006, 03:26 PM
Carel
Hello,
I'm just looking for absolutely straightforward hex nuts like a normal M12 nut but with a DIN103 trapexoidal thread. The backlash can be enormous, I don't care.
Regards
Martin
(sorry, I have to go home, I'll be back tomorrow)
Old 03-29-2006, 04:17 PM
*Registered User*
Martin, they are on the Duco Site you referred to:
http://www.huco.com/products.asp?p=true&cat=390
Or still more unobtainnuttable?
Carel
