| View Poll Results: If you only have an option of fitting one machine to the gantry, what would it be? | |||
| Router | | 330 | 80.49% |
| Dremel | | 39 | 9.51% |
| Something else (please specify what) | | 41 | 10.00% |
| Voters: 410. You may not vote on this poll | |||
#85
YouTube - CNC Stepper Motor Demonstration |
#86
| I agree that you shouldnt use a dremel for big machines , but if travel is less than or equal to 12", then they're good. (my opinion). One shame is the max shaft of 1/8". I was hoping to lathe down some bigger bits to have the smaller shaft ---------\\\\\\\\\\__________ 3/8"----- \\\\\\\\\\_________| <----1/8" ----------\\\\\\\\\\ But i dont think turning solid carbine on a mini lathe will be that successfull. sorry for off topic
__________________ A machine is only as accurate as the tools used to build it. "CNC = Computer Numeric Control - or on some days - CNC = Can Not Control" Imagineering |
#88
I think that it has to do with the thread being a poll, if someone votes it will flag as an unread post even if they didn't leave a comment.
__________________ I'll get it finished sometime after I start it..... |
#89
Exactly. I wish there were an option to turn that off.
__________________ Bob "Bad decisions make good stories." |
#90
| If properly designed, there is no such thing as "Only one option". Simply design your tool clamp to accommodate the desired tool to be interchangable. A Dremel is a very small tool, in comparison to a full-sized Router. Therefore, a tool clamp designed to fit a given Router, could easily be used to clamp around a smaller "Adaptor" mounting clamp designed to fit a Dremel, reciprocating engraver, or other small tool. Your imagination is your actual limit of your "Options"! |
