Since I built my machine I have used it extensivily for cutting lexan, and the odd bit of aluminium. Yesterday I cut a engine plate for a F15 ducted fan model I am building out of 1/4" ply. I found that the dust was fairly dark and the finished edge was on the black side but not burnt as such. Would I be cutting it too slow regarding feed ? (8" min) or is my cutter too fast. (my router goes from 15000 to 35000) it was set about midway. I never got round to building a bigger PSU for my machine so I am still running on a computor PSU with max speed about 12" min on my setup which has been ok for now. Just wanted to check from experienced wood cutters !! |
__________________ Gerry Mach3 2010 Screenset http://home.comcast.net/~cncwoodworker/2010.html (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by ger21; 02-15-2006 at 08:13 AM. |
| At 8 ipm, carbide will burn up just as fast.
| Hi I’ve cut lots of ply with a cnc router and find it’s a balance between feed speed, rpm and cutting depths. If your machine is at it’s limits where feed rate is concerned then it is as already said down to your rpm. If power is a problem at low rpm then cutting depth will have to be reduced and more passes made. One other point, use sharp cutters. TCT cutter are your only choice as tooling goes but I’m guessing you already knew this. Hope this helps, John |
