Old 01-23-2006, 02:33 PM
posix is on a distinguished road
Linear slide idea and questions
Having spent whole day looking for cheap stupid bearings and failing to find any at under $2 apiece, and when you need gazillions of them for a machine this thing doesn't come cheap, I've come across these. They are used in cabinetry for making built-in wardrobes and things. They come in packs of two, together with assorted plastic bits (guides, stops etc etc) and cost $2 for a pack of 2. Which means I just cut the price of this whole shebang in half! And they are rated at 90kg per roller! (they are meant to support large sliding doors with mirrors on them) Which is nice
They also have matching teeny bottom-supported rounded aluminium rails which are around $5 for a 3m length. Which suits me just fine!
Now my question is can any of you seasoned builders think of a better arrangement for the rollers?
Please have a look at what I came up with and see if you could think of a better arrangement which would offer better support for the whole assembly. I will be rotating everything 45 deg so I get support in all directions that matter for a particular axis.
And if you could stick to 4 rollers per side please as I don't want the costs to spiral out of control. It has allready cost me way more than I can possibly afford!
Name:	Linear slide - Front side.gif‎
ID:	14104   Click image for larger version
Name:	Linear slide - Left side.gif‎
ID:	14105   Click image for larger version
Name:	Linear slide - Perspective Top.gif‎
ID:	14106   Click image for larger version
Name:	Linear slide - Perspective.gif‎
Old 01-23-2006, 02:59 PM
rippersoft is on a distinguished road
I like it. Looks simple and the parts $$ don't kill you. I would build a prototype and beat it up. When I first built my roller bearing/gas pipe assembly, I put body weight on the assembly and pushed back and forth, side to side.
The sound of cracking parts or hearing a bindup will let you know if it will hack it. Of course, I would not suggest body weight for the plastic and aluminum you show in your design, but you get the idea.
I have stuck with roller bearings and steel angle and unichannel. Works good, won't break anytime soon.
Remember to play safe and above all, have fun.
Old 01-23-2006, 03:06 PM
Plastic are the sleeves for bearings. I didn't bother drawing bearings themselves but you can imagine the bearings come between the white wheels and the brass pins. I could take off the plasticky sleeves and replace them with brass or aluminium jobbies for example?
Old 01-23-2006, 03:33 PM
Is it even possible to make those 2mm wide 6mm deep cuts for aluminium support rails so close to a corner? Carpenters please respond...
Any better ideas?
Old 01-23-2006, 04:19 PM
I've made another version with two differing setups. The second one seems carpenter-friendlier Comments on stability of each please?
Name:	Linear slide right.gif‎
ID:	14111   Click image for larger version
Name:	Linear slide perspective.gif‎
Old 01-23-2006, 04:25 PM
rceebuilder is on a distinguished road
Posix, idea is good but you should use milled roller instead using ready built (moulded) plastic rollers .Once I have tried it. these wardrobe parts are not pricise enough.
But the rails are too nice and very easy to use
Murat
Last edited by rceebuilder; 01-23-2006 at 04:55 PM. Reason: additional information
Old 01-23-2006, 04:31 PM
Murat you are turkish! Wonderful!
Can you translate this for me from the packaging?
SKM30 HAFIF SURNE KAPAK MEKANIZMASI
(2 Kapak)
then it says din en iso9001:2000 blah blah blah which sounds pretty...
and the company is called MEPA
Ever heard of it?
Old 01-23-2006, 04:46 PM
The first one is better. It is more stable in rotational loads.
Old 01-23-2006, 04:49 PM
Posix , 'Light load draw slide mechanism'
Old 01-23-2006, 05:07 PM
Can you explain why is the first one better? I'm curious to know...
  #11   Ban this user!
Old 01-23-2006, 05:40 PM
Posix , at first sight I feel that it is more stable .it is also easy to use in X axis like this
  #12   Ban this user!
Old 01-23-2006, 08:03 PM
erase42 is on a distinguished road
there should be no problem cutting that groove in the inside corner of the block with a table saw.
