Old 01-17-2006, 10:04 PM
pyrojon is on a distinguished road
Small part favor for a friend
I need to make a "widget" as a favor for a friend. This thing will be molded in rubber but I need to make the original male part in order to make the mold. It's basicly a 2" x 1/4" round disk with some letters "carved" into one face. I tried to do it by hand but don't have the dexterity to do it right. It occurs to me that this is a perfect project for a cnc mill and since mine isn't complete yet I wonder if someone here can help me out.
I am happy to pay for shipping and materials and will even write the cnc code but am hopeing to keep it cheap since I'm doing this as a favor. (I could even send acrylic material, with extra for "Just in Case")
Any takers? Anyone have a machine that needs 10 minutes worth of work?
Thanks in advance
Jon
Old 01-20-2006, 08:24 AM
jcc3inc is on a distinguished road
Sir,
I may be able to assist you. If you could email me the Gcode which you have, and tell me what type cutter you need (Vee type, fluting cutter), I can cut a sample before needing your actual workpiece. Send to jccinc [at] owc [dot] net. If you do not have the gcode, then I need the characters required plus inner and outer radius.
Regards,
Jack C.
