I was thinking of taking the spindle out of my HF drill press, and using it for the CNC router. I would use a more powerful motor, and use the two pulley's to change speeds. The runout on the spindle is very good, so not much of an issue there. I don't know if the bearings are good enough though. I really want the 1/2" chuck for my tooling. Is it not advisable to use a chuck? I don't really see anyone with them. What do you guys think of the idea? |
Bad idea for several reasons... Drill press spindles are designed for axial loads, not radial - not rigid for side cutting as in routing. Bearings won't handle the speeds you use in routing - 10,000 ~ 20,000 RPM. You can run slower, but your cut quality will suffer Jacobs style chucks are not good at holding tools for side loading - only axial loading. I would even wager a guess that in routing wood at high speed, the vibration would cause the chuck to open and drop the tool. Stick with a router of some sort - even a small trim size router will get you going. Avoid the dremel type tools if at all possible, a trim router will have a much better spindle and bearings in it. Why is it that you want the jacobs chuck for tool holding? Chris |
| Plus, the chuck is held on with a morse taper, which will fall off shortly after encountering a side load on it.
| I ws going to say look at the new Bosch Colt. 1HP, variable speed. But no 1/2" collet.
| If vibration does not loosen the chuck it will loosen the taper shank the chuck is hooked to, but at least the cutter wont fall out, just the entire chuck Assembly ![]() As advised, look elsewhere. Ken |
| You guys beat me to it for some of these points. I had this same discussion with a couple of engineers I know recently. Gerry - I have actually had a morse taper attached chuck fall off while I was working. Not a pretty sight. |
| When you use a circle cutter (for wood) on a drill press, there's a reason they say 250rpm max.
