Old 11-21-2005, 09:43 AM
TonyWood is on a distinguished road
Unhappy ACME Screws in the UK
Calling all UK members.....Help!
Does anyone know where in the UK you can purchase ACME screws and nuts at sensible prices, I could order from the US but I will then get hit for import duty and it makes the saving almost not worth having.
Any links to good UK suppliers would be well received
Old 11-21-2005, 10:45 AM
ger21's Avatar
You might have better luck finding Trapezoidal screws, which are basically metric acme.
Old 11-21-2005, 11:17 AM
John S. is on a distinguished road
Halifax rack and screw - http://www.hrs-ccl.co.uk/
Kingston Engineering - http://www.kingston-engineering.co.uk/
John S.
Old 11-23-2005, 12:13 PM
Shedaholic is on a distinguished road
I would Recommend Marchantdice.com; they have sensible prices and to date have always given good (if not exceptionally fast) service. Unfortunately only the linear part of the website works but if you know what you want give him a ring to get a quote or have a look at his ebay shop (link from website) to get a rough idea of prices.
Old 11-23-2005, 12:49 PM
Tony asked for Acme thread and nuts.
As far as I know Marchant Dice only does ball screws.
John S.
Old 11-24-2005, 06:33 AM
I know I've bought 20x4mm trapezoidal for ~ £30 a meter including the VAT with about £15 for a brass nut from marchantdice's shop on ebay. Trouble is on his ebay shop he tends to label everything up as ballscrew for the search engine. Allow about a month though if you want the ends machined.
Old 11-25-2005, 02:29 PM
Shedaholic,
Good Call they seem to do everything for the home CNC builder and the prices are reasonable too, thanks for the heads up
Tony
Old 11-26-2005, 03:17 PM
Oldmanandhistoy is on a distinguished road
Hi Tony
Try http://www.ondrives.com . Look at din 103 leadscrews.
btw if delrin nut are ok for you make them your self real easy and cheap.
What you using them on (mill router)?
Regards, John
Old 11-26-2005, 04:24 PM
*Registered User*
marchantdice is on a distinguished road
We can offer Trapezoidal Assemblies with end machining in 5 to 7 days;
Spindle - 20 x 4 x 1000 Net £25.88
Nut (D = 45 x L = 40) 20 x 4 Net £22.64
http://www.marchantdice.com/linear
http://stores.ebay.co.uk/Marchant-Dice-Ltd
We appologise for using the term Ballscrew in all our adverts, Yes it is a metatag for the search engines and its what we do best! The ballscrew site is being re-written to help the "Home CNC market" and our industrial customers!
Old 11-30-2005, 03:23 PM
*Registered User*
Pat2000 is on a distinguished road
I realise this is a little bit of an old thread but I've just bought from http://www.huco.com/products.asp?cat=326 I had trouble myself finding a supplier.
14x4 Trapezoidal, perhaps a bit 'flexible' ! arrived protected well but still bent somewhat. quite nice finish on the 'flanks'
they accept credit card.
I'll make Delrin nuts from the shaft.
Pat
