is there a rule of thumb for machine size / gantry size or height etc in relation to the bearing spacing for the pair of bearings on each rail. I have HWIN style rails with a pair of bearings spread 8" apart (outside to outside) I am noticing the gantry will move slightly in the direction of the rails, at the point where the bearings are mounted on the rails. The movement will obviously be less, the further apart I space the bearings, at the expense of X Movement distance.
__________________ My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html |
My gut feeling is that you might have to move the rails in closer together, but by how much I'm uncertain. I would check your mounting to make sure there is no flex there first... |
| I have my rails mounted under the bed (just an idea I had to stop dust ... keep the bed area accessible etc) ) This effectively makes the gantry twice as high, so when you look at the front of the table X is front to back, the gantry is left to right. The movement is a tipping motion of the gantry top back and forth. I am really impressed as to the rigidity of the gantry, made from 12mm MDF in a torsion box setup, but I had my doubts about the bearing setup as soon as I installed them. This is just an experimental build so I can learn and see 1st hand how all this works, and what affects what. I'm using salvaged rails bearings screws and motors, which I am finding really limiting to how I wanted my machine to be. I still want it to be usable though, I have the Z left to make, and I can start test cutting . I have all the electronics wired and ready to go.I will use this to make another machine, as soon as it is capable
I'm using the idea in my current build as well. It's tough to find used or surplus stuff that's exactly the size you need, but I guess the hunt is part of the fun! |
| My surplus was donated by my dad. He did a job for someone in a factory, and saw they were throwing them out. They looked 'useful' so he asked if he could have them . I've just tried to get as much out of them as I could, hence trying to keep the bearings as close together as possible, without loosing out too to much movement and inaccuracy.
| T-slot spacing | dougtyler | Tormach PCNC | 7 | 10-27-2010 06:55 AM |
| air hole spacing? | ckrantz | Vacuum forming, Thermoforming Etc | 1 | 11-16-2008 11:43 PM |
| Help with equal spacing | MegaMoog | EdgeCam | 0 | 06-03-2007 08:45 AM |
| Angular Contact Bearing Spacing? | ngr1 | Benchtop Machines | 33 | 12-20-2006 06:44 PM |
| Linear bearing spacing & Sizing linear rails? | fyffe555 | DIY-CNC Router Table Machines | 3 | 12-07-2004 01:09 PM |
