  #25   Ban this user!
Old 02-22-2012, 06:24 AM
spaltiel is on a distinguished road
Originally Posted by louieatienza View Post
Like I mentioned, PAM High Heat cooking spra, at any supermarket. Leaves a nice finish as well...
Thanks. The attached image is your work?
  #26   Ban this user!
Old 02-22-2012, 06:58 AM
louieatienza is on a distinguished road
Yes, using PAM as a lubricant! 1" cast and ground aluminum, the ballscrew channel and counterbores are .438" deep. Cut with a Bosch 1617 and SuperPID... with steppers that supposedly have an underpowered power supply, leadscrews that are too coarse, and belts that cause backlash!
Also cut from the same batch: the adapters for the caarriage bearing blocks; there is a little bit of chatter marks, but still more than serviceable.
They're for my new machine; the thread in this forum.
ID:	153408   Click image for larger version
  #27   Ban this user!
Old 02-22-2012, 07:12 AM
WOW it is beautiful.
What is the depth of the cut in each step?
Did you also mill edges of the block?
How often did you spray with the PAM?
I have like tons of questions regarding parameters and so..
I am really amazed with your result. It is very nice.
  #28   Ban this user!
Old 02-22-2012, 01:37 PM
Thanks!
I usually only spray once. For multiple tool changes or multi-program setups I'll clean off the swarf and re-PAM.
I really feel having as much horsepower available helps, and since your spindle is more powerful than mine you should be good.
My parameters?
For pocketing, rough pass, I used a Onsrud 1/4" spiral Super-"O"-flute bit, at 50ipm, .08"doc and 12krpm. I helix in at 3 degrees at 25ipm. I normally go at 72ipm at .1"doc but my router is on it's last legs, so I need it to last at least until the new machine is done! My stepover is only 13%, but I'm at a greater depth and higher feedrate. I leave about .02" on the walls and floor, and switch to a coated 2-flute endmill (from either Kodiak, SGS, or Niagara) for the finish pass. I always clean and re-PAM for the finish pass. Spray it on, and use a cheap brush to coat all surfaces.
For profiling, I use all the same parameters, except I cut the doc by half. You're at a disadvavntage without flood, since the chips want to stay in the groove, so you'll have to watch and use air, or a brush, and keep that path lubricated. Again, I leave about .020" for finishing. To mitigate deflection on the finish pass I'll use the same step down as the rough pass, then do a complete pass the full depth to clean the edge up.
As you can see in the pics, even though I machined the pieces on different days, they still line up almost perfectly.
One caveat about pocketing: I use OneCNC XR4 high speed toolpaths, which prevent full-width cuts and corner ploughing. This lessens the anount of deceleration into corners and curves, and puts a constant load on the tool. If you're not using high-speed toolpaths, I recommend helixing in and spiraling out, with as much depth as you can but decreasing the stepover. Also pre-drilling at all corners can keep the bit from burying, where too much of the bit is "surrounded."
  #29   Ban this user!
Old 02-22-2012, 02:02 PM
In case you doubt 72ipm at .1"doc at 13krpm is not feasible on a home-made CNC, check it out! It's easy to say what feeds and speeds are, another to put it in action; so I'm putting my money where my mouth is!
  #30   Ban this user!
Old 02-22-2012, 02:17 PM
langwadt is on a distinguished road
Originally Posted by foam27 View Post
91% isopropyl alcohol works for me.
ethanol work great too, but spraying a flammable liquid all over the place isn't so smart, maybe it would still work if you mix in with enough water that cannot burn
  #31   Ban this user!
Old 02-23-2012, 06:14 PM
moswald80 is on a distinguished road
DIY CNC Router, cutting BMX chain sprocket, Part 1: Pocketing - YouTube
Wow, what CAM software are you using to generate those toolpaths?
Thanks,
Mickey
  #32   Ban this user!
Old 02-23-2012, 07:32 PM
Thanks,
Mickey
Using OneCNC XR4 Mill Expert's high speed toolpaths. I give a brief description about i above...
How Does CNC Routing Compare to Traditional Powertools Ecologically? marklavin Environmental & Alternate Energy 6 11-04-2011 07:51 PM
Cutting Aluminium djh82uk Benchtop Machines 58 06-26-2010 05:48 PM
Newbie- Help cutting aluminium Codeman General Metalwork Discussion 3 04-10-2010 05:49 PM
Need A Quote- For aluminium cutting btoes Employment Opportunity 5 04-15-2009 05:31 AM
Cutting Aluminium ninewgt General Metal Working Machines 3 07-29-2003 12:31 PM
