anyone tried driving directly to the router depth control ? I'm just thinking out loud here, as a temporary way to get my machine functional super quick ! I could then use it to make it's own 'proper' z axis Rich
__________________ My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html |
| no, I have a knob on top of my router that adjusts the hight of the bit. It has at least an inch of movement, so if I attached a motor to it, I could direct drive it. I probably wont, and just make a proper Z, but the idea seems interesting !
They make CNC xy tables for mills. IIRC you can set this up in Mach3 and have it prompt you when to do a z level change. There was an article on exactly this in a previous issue of Digital Machinist... |
| good to get you out of a sticky situation if a motor or driver died ! I'm still thinking the the router base could be actually used as the Z It has the unsupported rails and all thread rod for a screw. And the router mount built in the more I describe it, the more it seems like a good idea ! LOL ! Rich
| It's this one. The springs hold the router up against the screw which brings the whole lot down against the base. So if I fix the base to the Y axis, the screw labeled in the pic, would be the Z drive
| oh, and yes, there is a cam lock, so hold the position anywhere between the Z stop and the fully down position
| I don't think a plunge router is smooth enough for it to work with a stepper. I think it will bind. But you never know.
#10
| well, and experiment for one day then. When you think what the metal guys do with their sliding dovetail beds ! ...
#11
On some of the higher end machines, the ways are layered with a material like Turcite, which allows smooth movevment. Some are manually or automatically oiled; even the small Sherline has an oiler... |
#12
| well, I'll leave it for a rainy day then, when I have nothing better to do. back to the build
| Help! - No Movement | jeremysartor | Mach Software (ArtSoft software) | 4 | 12-12-2010 12:37 PM |
| Need Help!- no x y z movement | bullseye | CamSoft Products | 4 | 07-28-2010 08:39 PM |
| Need Help!- G02 but X Y Z movement | PEU | G-Code Programing | 5 | 02-18-2010 05:06 PM |
| Need Help!- Can not get any movement from C6 lathe | J. Moran | Syil Products | 28 | 03-10-2009 10:00 PM |
| No Movement | wishmasterg | Mach Mill | 3 | 02-14-2007 06:39 PM |
