Old 11-13-2005, 03:46 PM
PEU's Avatar
PEU PEU is online now
PEU is on a distinguished road
How To cut a sheet of Stainless Steel
A friend of mine gave me as a gift a supernice sheet of stainless steel (0.5mm / .02" thickness) that I want to use in my router to cover certain parts.
The sheet is big, around 1 x 1.5mts so there is plenty of space for try&error but I dont have a clue on what is the best way to make a clean cut thru it.
So, whats your best advice for cutting this sheet?
Pablo
Old 11-13-2005, 07:46 PM
trubleshtr is on a distinguished road
Ideally a shear/brake. but how many of us have one of those???
you could use a grinder and a cut off wheel if you got a steady hand...
menomana
Old 11-13-2005, 09:28 PM
Mcgyver is on a distinguished road
Me , nice big cast iron 4' Brown Boggs, hey it was cheap, but that doesn't help you Argentina
I'd use hand tools. its only .020, with good hand snips it will cut easily....but do get good ones, the cheap ones are just frustrating. Wise calls them patterns snips, I’ve found them to be good
http://www.cooperhandtools.com/brands/wiss/index.cfm?model_list=1&att_id=WIS002&att1=Snips&att2=Tinner's
If you want to get fancier and cut radii you can get left and right cutting aircraft (compound) snips
Old 11-13-2005, 09:46 PM
PEU's Avatar
another tool for the shop hope these are not expensive
Pablo
Old 11-14-2005, 11:14 AM
Unabiker is on a distinguished road
A couple of other options, depending on what sort of shapes you want to cut.
If you want to do curves:
Perhaps a Beverly (throatless) shear. Here's a cheapo Harbor Freight version http://www.harborfreight.com/cpi/cta...emnumber=38413
Maybe a nibbler....HF options http://www.harborfreight.com/cpi/cta...emnumber=46061
http://www.harborfreight.com/cpi/cta...emnumber=91739
http://www.harborfreight.com/cpi/cta...emnumber=43063
Or perhaps an in line shear:
http://www.harborfreight.com/cpi/cta...emnumber=36568
If you're just after straight cuts, you can't beat a good ol stomp shear, though it would be pretty cost prohibitive for just one project. That being said, I have a 36" Pexto shear that gets constant use.
At only .020", I would be awfully tempted to let the router have a whack at it using a single flute Onsrud bit like this: http://www.onsrud.com/Products.asp?A...1%3A12%3A14+AM
I have not tried this personaly, but .020 is awfully thin stuff. You would probably be albe to tell if it's a go or no in the first inch or so.
Old 11-14-2005, 12:06 PM
PEU's Avatar
Unabiker, one of the links you provided appears to work like a die grinder which I have:
What tool do I need to cut the sheet with it?
Pablo
Old 11-14-2005, 12:10 PM
Gold Member
InspirationTool is on a distinguished road
I've been able to use a jig saw just fine. A bit slow, but it works.
-Jeff
Old 11-14-2005, 12:36 PM
whateg01's Avatar
whateg01 is on a distinguished road
I would like to be able to cut 17 ga. SS sheet. I have been using a cutoff wheel on an angle grinder, but a cleaner, quieter method would be great. I have a shopbuilt throatless shear, but it is only capable of soft metals such as brass and aluminum. What type of material do the blades need to be made of? Hardness? etc?
Dave
Old 11-14-2005, 02:33 PM
Chris Roth is on a distinguished road
I have cut with a jig saw also & works good. if you are going to grind the edges use breathing filter of some kind. You only get one set of lungs!!!
Old 11-14-2005, 04:47 PM
Pablo,
All of those nibblers that I linked work like a punch. There is a little die that moves up and down an punches out a little chunk of material. When it's cutting, it will shoot out little toe nail shaped bits of metal.
I think the one you are talking about actualy goes in a drill. A die grinder would probably turn way too fast.
I've got this one: http://www.harborfreight.com/cpi/cta...emnumber=46061
It would easily cut that .020" sheet. You can also get a replacement foot and die if need be. It's not the highest quality tool in my arsenal, but at $29.99, it doesn't need to be either.
Dave,
I'm not sure what material the blades on my Beverly shear are made of. If I had to guess, I's say probably hardened high carbon steel. That particular shear of mine is probably at least 50 years old. I think the blades' sharpness is more important than thier ultimate hardness.
  #11   Ban this user!
Old 11-15-2005, 09:49 AM
energyforce is on a distinguished road
I need to cut a 4foot x 2.5foot sheet of aluimum into several pieces. None of the pieces will have round edges. The aluminum is 1/4" thick. Im thinking of using a zipcut (grinder abrasive wheel) on a skillsaw. Would this be an okay route to go? It is the "free" route for me but if its not gonna work at all then ill have to do something different.
  #12   Ban this user!
Old 11-15-2005, 01:00 PM
energy, I've never done this so check around first to make sure, but there lots of acounts of doing so with a table saw or skill saw with a regular carbide tipped blade - the main danger seems to be they give one hell of a kickback.
