02-04-2012, 11:08 AM
Originally Posted by adprinter I drilled a thru hole at X0Y0, and X26Y0- then flipped the piece, and inserted a foam rubber pad under the stock (to provide support for the piece already cut), then loaded the mirror image file, and painstakingly jogged the machine into alignment with the thru holes, and re-zeroed X and Y... |
This was an inaccurate statement (I did NOT Re-Zero X and Y in Mach3)- the rest of the process is what I did to "Find" zero on the X and Y. To Shargo, Thanks for the tip. I actually considered doing just that. But the problem was the stock size I was working with, did not leave enough room outside the carving area to accommodate registration holes. Obviously pins could not be used inside the area to be carved, as this would have resulted in damaged cutters. I am working on a jig plate, to be permanently bolted to the table, with two pins for registration which will be located outside of the carving area. All future stock pieces would then be drilled outside the area to be carved, and mated to the pins. I agree that it would make things a LOT easier. Simply remove the stock after the first side is cut, place the foam support on the table, flip the stock and seat it onto the registration pins, load the mirror image file, and click cycle start! |
