I have been wanting to build a CNC Table for a few years, and today is the start of my addiction ![]() I have picked up some linear drives and servos and aluminum channels from Foxy Recycleing in Ottawa, Ontario for 200.00 and this is what I got. Post 2 will be more of a description of possible layouts for the table Thanks Doug Morency Kemptville, On |
I want to build a table that I can use to mill templates for RC Airplaine out of Hardboard, and also cut 6mm foam and 6mm Depron for airplanes. here is my thoughts of the layout. The 2 black linear Rails by Thomson are joined by a chain with the Stepper Motor is an API Controls m342-09 S-C1. So I am planning on using those for the X Axis The silver aluminum one with the e2440-324 Oriental Motor Company Stepper, I will use as a Y Axis. I am not sure if I should use the second Aluminum on as the Z axis or just build one from scratch using the stepper motor. e2440-324 Oriental Motor Company. I would like to use a laser to cut the foam, or my just use a xacto blades to do the cuts. I want to control it all with an arduino based stepper controller, connected to a dell netbook. What do you all think of this design. Thanks Doug |
| It should take you to manufacturer's website where you can read up on the specifications. May take awhile to find the right site, but once you do you will know. Generally, bipolar motors will have 6 or 8 wires coming out of them. You can determine which wire is what, using an Ohm meter. Unipolar motors I am unfamiliar with, but Bipolar will have at least two coils in them. (Ohm meter should read zero resistance between the two wires which are going to a single coil). But this can be confusing, as you can also get a reading of zero between more than 2 wires! (Like between 3 different wires). This is when you need to pay close attention to the actual reading of the meter. One of the 3 wires may have say .005 Ohms reading on it. This indicates a "Tap" which effectively splits the coil into 2 segments. This can all get very confusing, without the info from the manufacturer. So, do the search, and find the Specifications for your particular motors. Which identifies the color coding of the wires coming out of the motors. |
| correct me if i'm wrong, but actually unipolar motors have 6 or 8 wires: one for each coil and a common between two coils, or two wires for each coil, two of which need to be connected together to make a common wire for a pair of coils. as the picture says, you can make unipolar into bipolar motors. quote from wikipedia (i actually tried this, and it works): For the experimenter, the windings can be identified by touching the terminal wires together in PM motors. If the terminals of a coil are connected, the shaft becomes harder to turn. one way to distinguish the center tap (common wire) from a coil-end wire is by measuring the resistance. Resistance between common wire and coil-end wire is always half of what it is between coil-end and coil-end wires. This is because there is twice the length of coil between the ends and only half from center (common wire) to the end.) A quick way to determine if the stepper motor is working is to short circuit every two pairs and try turning the shaft, whenever a higher than normal resistance is felt, it indicates that the circuit to the particular winding is closed and that the phase is working |
| I hope to get laying out the table this week to see what I need. Thank you all for your input. Doug |
#10
There have been a few I have seen and |
#11
Turns out the e2440-324 from Oriental Motor Company, is some kind of OEM device, and they have no idea who's number it is. I will be taking it apart and see if I can find more info in the inside of it to figure out how it is wired and how it works, and then I would like to see if there is a way to see if I could control it with PWM. Time will tell, If not time to go find a couple of other stepper motors. Doug |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| First Router Table Build 4x4 | Ferrari2007 | DIY-CNC Router Table Machines | 4 | 04-04-2008 09:55 AM |
| Need Help!- Need advice on router table build | jdcn05 | DIY-CNC Router Table Machines | 2 | 01-27-2008 04:02 PM |
