I use a 24.000 rpm 1600 Watt commercial router as spindle. My 3axis CNC router must work 8 hours in a day, cutting hardwood. But spindle always fails. Sometimes the bearings, sometimes brushes. I plan to use a AC 3 phase squirrel-cage motor. It is 3000 rpm, 2 HP. I will increase the rpm using a timebelt. Are there anybody having same trouble? Any other suggestion? P.S. (I don't plan to use 5000/10000$ commercial high speed spindles) |
| You can get one of these for $2000-$3000. Either the 1.34HP or the 2.68 should work much better for you. http://www.ekstromcarlson.com/router_packages.htm
| Walter's solution is a good idea. You could probably also buy one of the store warranty policies so you can quickly exchange the routers locally when they fail. They might not be too happy when you come in to exchange the product every other week... but hey *shrug*... |
People who use Porter Cables 8 hrs/day or more replace brushes monthly, bearings every 2-3 months. |
| I had the same problem with an El Cheapo router, the bearings and brushes just don't works as long as I expected, one idea is to slow down speed with a Variac, from in my case, 30000 rpm to just under 18000 rpm, it seems that this speed is the best for ordinary high speed ball bearings. But... can I cut with this low speed I use various materials like MDF,Masonite, Plexi and aluminium, maybe I should run in short spell of work. Leffe |
#10
