I'm getting ready to start building my first cnc router and have a question about the travel distance for the Z axis. Is there a standard amount it should be set at? All I plan to use this machine for is cutting shapes in 1/8 inch birch wood. So I do not need as much travel in it as others. The reason I ask is if I can build the gantry to be not as tall even by a few inches, won't that take away any chance of it swaying? And once its built, do I do some sort of calibration in the setup of the software to tell it how far each axis will move and its limits? Off to HomeDepot! I have the following so far: 1/2-10 acme threaded rods AB nuts ordered from Dumpster on here Xylotex 3 axis driver board Nemo 23 269 oz/inch motors (3 of them) Power supply / fax from Xylotex 1" drill rod Roller bearings I plan to build it very similar to JGRO's design but will extend the X axis some and support the linear shafts on each side to reduce any flexing. I will be posting a log with pics on here as I build it. Thanks! Warren |
| You need to allow for whatever different size tools you'll be using, how the router mounts, and the material thickness. If you're just cutting 1/8", you could get away with as little as 1". I'd shoot for 2-3". You might find a lot more things you'd like to do when you get it working.
| help! please. how i can make short ascend and descend for z axis on mach 3. the DRO for z axis say +60.0000 when is on top and +0.000 when is down to material. normally +0.0000 is the top of the work piece, but from +60.0000 to +0.0000 is a long travel. i already see some videos on the web for cnc machines with short ascend and descend on his z axis. please help!!!. |
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| THANKS! for the answers. but i mean when i open a g-code on mach 3 the z axis move to +60.000 on the top, and move down to +0.000 that's is ok but +60.000 is the probelm from +60.000 to +0.000 take time in the ascend and descend movement, i want to make short ascend, this is not speed setting related. if you get too much speed to the motor it will lose step synchrony and sudden stops . something like +40.000 is ok, i'm starting to think the problem is on the g-code i must edit the g-code i think. |
hth
__________________ Keith |
| Do you have Safe Z set at 60? If not, it's probably your g-code.
| hello!. thanks for your help. i manage change the huge +60.000 values on gcode for z axis, i found that you can put any values for any axis and you can say to all axis go to specific position after of work is done. i already learned many things on mach 3, now i can complete the the tests for athc, analog torch height control, i want to say, thanks for the help and support!!!!!. news on athc coming soon stay tuned!! |
