Old 10-27-2005, 12:33 AM
mikie is on a distinguished road
Protype machine - My first CNC Part
Hi All,
I finally churned out my first CNC part last night with my protype CNC.
WOW - I think it would have been cheaper to buy the part at the local hardware store for $20 bucks!
For those of you interested, I have a few pictures of the unit.
It's 1000mm(X) X 600 mm(Y) X 150mm(Z)
The slides are 1/2" pillow blocks for the X and Y Axis.
I obtained the Y-screw in my travels and is 4mm metric.
The x-axis is a belt drive system, which utilises the cam belt and pulley from a Daihatsu van.
The z-axis is a Acme thread.
The stepper motors are driven by Gecko's and I am running Mach3 to drive the system.
Issues:
I have found that the 1/2" rails on the X-axis are not adequate. There is flex present which needs addressing.
The x-axis requires some sort of gearing as i am having trouble driving the unit in the x-direction. I am finding that as the tool drives into the material, some skipping of the stepper occurs, or the entire gantry starts porposing due to the tool biting.
I would also like looking at putting the Gecko's away from the unit. There is far too much wiring on the machine.
A dust extraction system will need to be deployed as it just gets everywhere.
The effective cutting envelope is reduced due to the Z-axis unit width.Effectivly, you loose about half the width of the Z-axis
The x-axis is reduced by half the width of the Y-axis. I would like to re-engineer this for my next machine.
I had to add a third rail to the Y-axis as I had the initial 2 rails which guide the Y-axis too close together. The weight of the router itself then caused the entire Z-mechanism to sway forward and at times sway when i tried to cut. I added a third rail up as high as possible and this added a large amount of rigidity to the whole gantry.
Hope this helps some one who builds a machine in the future
/Mikie
ID:	11411   Click image for larger version
Old 10-27-2005, 05:45 AM
dighsx is on a distinguished road
Hey congratulations Mikie. I just finished my first machine and I know that feeling of shock when the thing actually does something.
Take it easy.
Jay (www.cncjay.com)
Old 10-27-2005, 09:13 AM
LetterCAM.com
WarrenW is on a distinguished road
Does the X axis only have trouble moving when your cutting? Does it move okay when its not cutting? I was thinking maybe the linear shafts are not aligned and could cause some binding. I plan to use some mounting blocks for mine so I can adjust it anytime.
Too bad your not using open end bearings because then you could add a support for the X shafts to keep them from flexing. I have 1" drill rod I plan to use but I'm going with the ole rollerskate bearings method for now and will be adding supports on the shaft to prevent any flexing.
Nice work though! I can't wait to get mine together...
Warren
Old 10-27-2005, 06:28 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
BUT, you can't buy the fun factor for $20
Dennis
Old 10-27-2005, 06:42 PM
Jason Marsha is on a distinguished road
DITTO.
Jason
Old 10-27-2005, 07:34 PM
Hey warren,
Yeer it moves great without load, so it is defintly the direct drive system from the stepper motors. I always figured it would give me grief, but i will use this machine to build the reducton gear which i will retrofit to this unit.
I also have a 300oz/in stepper available to use, so i will make everything up with this unit and then drop it in to the unit.
True - about the fun factor, plus the satisfaction of producing something from nothing.
Old 10-27-2005, 07:44 PM
Evodyne's Avatar
Evodyne is on a distinguished road
Mikey,
Congratulations!
