Old 10-23-2011, 03:12 PM
cd_edwards's Avatar
cd_edwards is on a distinguished road
spindle motor option
I fly model helicopters in a smaller size but wanted to get into quite a bit larger size. I ended up ordering some parts for one including a motor. The Align 700MX has the following specs. Has anyone considered using one of these as a spindle? I would have to think that this particular motor with an appropriate speed controller and large ass power supply would do a pretty good job as a router. Only difficulty would be mounting a ER8 collet onto the 6mm shaft on this motor. This motor is three phase and designed to be used in large electric planes/helicopters with integral cooling. It's a outrunner design. The speed controller's have a PWM input from the radio reciever for throttle control
- Input voltage: DC11.1V-50.4V
- Max continuous current: 90A/150A(5sec)
- Max output power: 4000W/6600W(5sec)
- KV value: 530KV
- Stator Arms: 12
- Magnet Poles: 10
- Dimension: spindle Φ6xΦ52x57.5mm
- Weight: 405g (prox.)
Old 10-23-2011, 03:51 PM
cd_edwards's Avatar
replying in my own thread. found another thread here on cnczone concerning these types of motors. really should learn to use search first.
Spindle Motor for Taig ER16 Spindle jupdyke Taig Mills & Lathes 10 04-15-2011 11:33 AM
Komo VR804 spindle reverse option paul bandy WoodWorking 0 05-12-2010 05:21 AM
New spindle option from Proxxon.. krazatchu DIY-CNC Router Table Machines 0 11-17-2009 09:37 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
TM-1/TM1-P Spindle Option HelicopterJohn Haas Mills 1 10-31-2007 10:35 PM
