Hello all my name is Chris Delicath and I have been camping out here on the site for a while learning what I can and I have finally decided to build my machine. I will be using the machine primarily for cutting acrylic and poly-carbonate from 1/8" to 1" thick and maybe some lite aluminum work if possible. I wanted to start this thread to get constructive criticism and ideas as I build so any feedback is welcome. Last edited by cdelicath; 10-23-2011 at 09:23 PM. |
| For the supported rails, You should look at Galcern as well Galcern SBR. Note the Galcern prices include 2 rails and 4 blocks. Dennis |
| For your needs I think 16mm is probably enough, you can find them quite cheap on Ebay if you can wait for overseas shipping (chinese seller Linearmotionbearings2008, you can contact him for custom lengths). My machine uses chinese 16mm rails and it works great. I work mostly wood and plastic, but occasionally do some aluminum work and they're working fine. Remember to drill holes so you can access the blocks' adjustment screws after mounting them. What are you going to drive the machine with? (ACME screws, ballscrews, rack & pinion, belt drive...). |
| Not overkill at all. Actually, I'm worried you might have screw whipping problems at such length. I've never used ACME screws so I don't know how hard or straight it is, but it would probably be a good idea to go with a bigger diameter if possible. |
#10
| I don't know what would be the right diameter for that length, but I guess 5/8" would probably be the minimum I would use for X (5/8" would probably be enough for Y, and 1/2" for Z). I bet someone that had actually used ACME screws will post a more convincing answer than mine |
#12
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| Build Thread- Brilliant Design 72"x36"x9" CNC Router (HobbyCNC based) | vondeliusc | DIY-CNC Router Table Machines | 3 | 05-31-2011 11:14 PM |
| New Machine Build- My take on a "desktop" 32" x 15" x 9" 'router' | Riceburner98 | DIY-CNC Router Table Machines | 9 | 03-25-2011 04:21 PM |
| New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105 | Modular CNC | Open Source CNC Machine Designs | 0 | 11-08-2009 11:36 AM |
| Need some advice on DIY 24"x24" CNC Router Table... | kanankeban | DIY-CNC Router Table Machines | 27 | 06-01-2004 06:38 AM |
