I've just purchased Gerrys MACH 2010 Screenset.. so decided to setup a probe. This is how I've done it: See attatched image. Is there anyting wrong with usining a relay? I've tried it out it appears to work ok.. but my knowlage of this kind of thing is limited. help/comments much appreciated. oh and thanks to Gerry for such a great screenset!!! ![]() cheers mick |
| I haven't tried it, so this is just a guess... How fast is your spindle moving when you are checking the probe? How fast can your relay be actuated? If you have a fast-moving spindle height and a slow-actuating relay, then your probe height determination could be off, or your tool could try to plunge into your probe plate a bit before it stops. |
| That's exactly what I was thinking... I was hoping I was wrong. I'm sure any delay wont be huge but I sure don't want to risk damage to the tools.I'm not sure of the z feed-rate, I am just running the Mach 2010 Screen set with the preconfigured auto zero macros. How are others wiring this? Mike... |
| I just have the plate wired to an input pin with a pullup resistor to 5V, with the spindle to ground. If you're set up in metric, it probes at 250mm/min, then again at 25mm/min.
| G540 Relay Wiring - Quick Question | strohkirchw | Gecko Drives | 0 | 12-06-2010 03:37 PM |
| Wiring diagram for Gecko g540 and cnc4pc C8 relay | blackrat | Gecko Drives | 2 | 04-25-2009 05:22 AM |
| embarassing relay wiring question | endgrainguy | General Electronics Discussion | 5 | 01-14-2009 07:40 PM |
| TREE 310/325 Relay wiring diagram | ken fedirko | Tree | 3 | 02-10-2008 10:55 AM |
| Wiring a relay into my 3 phase motor | Bass_Player | General Electronics Discussion | 6 | 05-24-2005 09:50 AM |
