Old 10-22-2011, 02:03 AM
andlb is on a distinguished road
Handpiece and shaft
Does somebody know what handpiece/spindle, flexshaft and motor the lumenlab machines are using, or if there is a good substitute?
/ Andreas
Old 10-22-2011, 03:42 AM
Ron Dunn is on a distinguished road
I believe they are using Weecher handpieces. Hard to tell these days, it looks like Lumenlab is about to go under and there isn't much information coming out.
I'd look at the heavy-duty range of Foredom spindles. Might cost more, but at least you'll have a known source, somewhere to go for spares and repairs, and probably even a warranty.
Agie handpiece membrane switch pad Colin EDM Machines 5 06-07-2011 08:40 AM
Foredom # 25 handpiece tootalew DIY-CNC Router Table Machines 3 08-27-2010 05:38 AM
need help in shaft dispalcement saraswathi Mechanical Calculations/Engineering Design 2 04-01-2009 04:48 PM
Newbie- Spindle from High Speed Foredom Handpiece? ynnek DIY-CNC Router Table Machines 9 05-23-2008 10:18 PM
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
