Old 10-19-2011, 11:38 AM
Michael In Cali is on a distinguished road
Looking for really slinky dust collection hose
I'm looking for a source for some really slinky dust collection hose for my DIY wood router. Something in the 1.0 to 1.5" range. I'm trying to minimize stiffness in the Z axis as well as the X and Y.
I found a hose at McMaster that was advertised as very flexible, but its not flexible enough.
Something like the RV sewer hose in a smaller diameter would be nice. I'm looking for it to accordian nicely.
Any thoughts?
Old 10-19-2011, 01:44 PM
vtx1029 is on a distinguished road
Maybe try the flexible water drain pipes for sinks.
Old 10-19-2011, 03:13 PM
DonFrambach is on a distinguished road
You might like this:
Amazon.com: Shop-Vac 9013400 2 1/2-inch x 10-foot Replacement Hose: Home Improvement Amazon.com: Shop-Vac 9013400 2 1/2-inch x 10-foot Replacement Hose: Home Improvement
It's very flexible and the ends can be removed and replaced so that the hose can be made the perfect length.
Don
Oops, just realized you want something only 1 to 1.5".
Old 10-19-2011, 05:17 PM
ssutton is on a distinguished road
Search for a material called santoprene (sp?) McMaster usually has it. I don't know if that is what you bought or not. I purchased it for a vac application at work and got it in 2" size. The hose that I got was wire reinforced so that it could withstand the vac pressure, it was VERY flexible.
Scott
Old 10-21-2011, 06:50 AM
boblon is on a distinguished road
Did you find your hose yet?
I have a very slinky small hose at home, I don't remember how I came to have it. I know I don't use it. I don't know what size it is but I THINK it's in that range. I can check when I get home.
If it will work and you want it, it's yours for shipping costs.
BobL.
Old 10-21-2011, 09:48 AM
BobL, Thanks for the offer. Depending on diameter and length, it may be worth persuing.
Others, thanks as well. I did not see santoprene in a hose form on Mcmaster. Other products made with it though. The hose I bought was Blow-R-Vac hose and the picture shows a slinky hose, but that is not what I got. Semi-rigid hose like a ShopVac hose won't work either. I need it to flex along its length and have a fairly sharp bend radius.
I use RV sewer hose on my manual router table and it looks like this. Compresses like a slinky. 4 feet of hose compresses to just a few inches. However, RV sewer hose is 3" and the application doesn't need 3". I usually don't have too much trouble finding things like that, but I seem to be lost.
I'd take a picture, but I'm at work.
Old 10-21-2011, 02:13 PM
I don't know how long they need to be, but I have 4. Two of them have a hose diameter of 1-1/2" and the other two hoses are 1-3/4".
They are very slinky. I don't know how a hose could be any more slinky than these.
Anyhow, you can have two of them if you want. Don't know how much these pics are worth, but hopefully you can see in the one that shows them hanging that they do not come out very far until they are vertical.
Anyhow, your call.
BobL.
ID:	144461   Click image for larger version
Newbie- dynatorch set up for duct work thin ga vsm12 DynaTorch 2 06-23-2011 03:58 PM
Need Help!- Dust collection hose....where to find it! mlabruyere DIY-CNC Router Table Machines 10 02-05-2010 03:22 PM
importance of internally grounding dust collection hose? groomden DIY-CNC Router Table Machines 10 04-16-2009 08:30 PM
Dust collection hose diameter postalgbv Commercial CNC Wood Routers 6 12-02-2008 09:39 AM
CNC for a/c duct liner WMACS Open Source CNC Machine Designs 0 10-02-2007 01:18 PM
