Old 10-17-2011, 10:16 AM
deannos is on a distinguished road
DXF/g-code files for trend T3 router mount
Hi, are there any DXF files or g-code for cutting a router mount.
Old 10-18-2011, 06:33 AM
CarveOne is on a distinguished road
Since it has no round body it will not be likely that you will find anything other than a plate that the lower end of the router is mounted to.
To make such a plate would involve removing the plunge base and rods. Then measure the spacings of the holes in the router that can be used to attach the router to the plate. Then the plate needs threaded holes in one edge that allow mounting the plate and router to your Z axis.
K2CNC in the US sells router mounts but doesn't show one for the T3.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
G-code files for fabbing an adapter to use a Bosch router with a Tormach mill Peter H EBAY ADS 0 09-08-2011 11:40 PM
Need Help!- Trend router mounting Drakkn Want To Buy...Need help! 0 03-01-2010 04:20 AM
SolidWorks Files For K2CNC Mount and Hitachi Router solodex2151 DIY-CNC Router Table Machines 0 06-10-2008 06:18 PM
Need A Quote- Bracket to mount Trend T3 Drakkn Employment Opportunity 0 05-07-2008 06:26 AM
Trend T3 Router question Drakkn Wood Working Tooling 4 11-19-2007 07:00 AM
