Old 10-07-2011, 07:19 AM
marting is on a distinguished road
Tool Changer for CNC router (or spindle)
Hi to all. I have built CNC router with a working area of 750mm (X) x 550mm (Y) x 250mm (Z) and have been working with it for the past 3 years. Now I am considering building a bigger one with a bit of more sophisticated features such as 5 axis, automatic selectable vacuum table, fluid cooling in case I'll be needing it in the future and tool changer. So far I seen many variations of the fore mentioned features but have never heard anyone of designing a CNC router (even if a spindle is to be used instead of a router for that matter) with a tool changer. Is there anyone on this forum with such experience?
Marting
Martin G
Old 10-07-2011, 07:50 AM
rowbare is on a distinguished road
There are a few ways to do it. There is the wine rack style where all of the tools are in a rack and you move the spindle over the tool you want, here is one example:
Majestic Machinery have some tool changer components available:
Majestic Machinery | Automation
They built this router: http://www.cnczone.com/forums/cnc_wo...ew_router.html
Another approach I have seen on you tube is to have 4 spindles on a vertical carousel which rotates to select the spindle though this is probably not appropriate for 5 axis....
Oh have you priced 5 axis CAM software?
bob
Old 10-07-2011, 08:25 AM
ger21's Avatar
Expect an ATC spindle with toolholders to run between $4000 (small chinese from Keling) to $10k-15K (larger HSD spindle).
This machine has a chinese ATC spindle, but it's not finished yet.
http://www.cnczone.com/forums/cnc_wo...ediculous.html
Old 10-07-2011, 08:59 AM
fixtureman1 is on a distinguished road
Blurry cnc has a tool changer that may work for you
Need Help!- Tool Bit & Spindle Choice for Router brw0513 DIY-CNC Router Table Machines 2 09-12-2011 03:45 AM
Need Help!- Spindle and tool changer problem kinmo84 Machine Problems, Solutions , Wireless DNC, serial port 0 01-05-2011 07:18 AM
DIY ATC automatic tool changer for cnc router.. Mythical or reality? rodjava DIY-CNC Router Table Machines 9 07-27-2010 08:58 PM
Need Help!- CNC router w/tool changer LarryP Commercial CNC Wood Routers 4 03-01-2009 10:35 PM
