Old 09-30-2011, 04:05 PM
Darylb is on a distinguished road
FLA-100 Z-axis Acme Question
I'm about to order some of the parts bundles from FineLineAutomation to build the FLA-100. I notice there are option to make the Z-axis either 1/2-10 5 start ACME or 1/2-10 1 start ACME.
I realize the 1 start will be slower with higher resolution, while 5 start is faster with lower resolution however which one would you guys recommend?
Old 09-30-2011, 05:46 PM
ger21's Avatar
I've only used 1 start personally, and it's much too slow. I'm using 1/2-8 4 start for my new router. Which is basically the same as 1/2-10 5 start.
Acme Rod Question DistortedDesign Joes CNC Model 2006 4 03-10-2009 11:18 AM
Acme Question Micky15044 Open Source CNC Machine Designs 4 07-11-2008 08:34 PM
Acme rod question THend Linear and Rotary Motion 5 03-21-2008 12:37 PM
acme rod question Kev DIY-CNC Router Table Machines 3 10-12-2006 03:26 PM
Acme nut question SPEEDRE Benchtop Machines 1 09-18-2006 02:23 AM
