Old 09-17-2011, 11:48 AM
Rob K is on a distinguished road
Preferred Stepper
Does anyone have experience with either of these steppers?
I'm looking for steppers to match up to a Gecko G540. I've tentatively narrowed it down to 2 Keling offerings:
KL23H284-35-4B
KL23H2100-35-4B
I'm running dual steppers/screws on the x-axis. Should I go with 2 smaller steppers on this axis?
My machine is roughly 2'x4' and will be used for wood, aluminum, plastic, & possibly circuit boards (if the resolution comes out good enough).
Any other stepper recommendations?
Thanks in advance.
Old 09-17-2011, 01:47 PM
doorknob's Avatar
doorknob is on a distinguished road
KL23H284-35-4B
KL23H2100-35-4B
Strictly from the standpoint of matching the motor parameters to the capabilities of the G540, the KL23H2100-35-4B appears to be a better match.
The G540 has a maximum voltage limit of 50 volts.
Based on the formula of 32 * sqr(winding inductance in mH), the maximum recommended voltage for the KL23H2100-35-4B comes out to 53 volts, which is closer to 50 volts than the maximum recommended voltage for the KL23H284-35-4B (which comes out to 64 volts). So if you get the KL23H284-35-4B, you will not be able to get the ultimate motor speed out of it, because you will not be able to apply as much voltage as it "wants".
Inasmuch as there are other factors besides applied voltage that could affect the actual maximum obtainable speed out of the motor, I can not say for certain whether or not that difference would be significant in your application.
Preferred stepper motor type for a door lock grandruby Stepper Motors and Drives 8 08-19-2010 07:25 PM
Machinists Wanted - Swiss Preferred -KC, MO kctechlink Employment Opportunity 0 12-20-2006 12:08 PM
Preferred Stepper Driver Electrical Interface JeremyLee Polls 4 02-26-2006 03:08 PM
Preferred file for RFQ turmite Employment Opportunity 5 01-24-2006 05:37 PM
The AMSOIL Preferred Customer Program WallCrawler Product Announcements & Manufacturer News 0 07-20-2004 09:45 AM
