Old 09-16-2011, 09:04 PM
czwalga is on a distinguished road
Understanding the zero points software vs my solsylva.
Alright my solsyva isn't completed yet, but i've had some time to play around with cad/cambam.
I've yet to interface to mach3 or anything of the sort.
So I've imported a small dxf into cambam, made the necessary pockets and drillings. My question is my drill points start at 0, and go to -.30
My question is how does the CNC software know exactly where the zero point is, it's going to depend on the tool and thickness of the wood. I've read a lot of tutorials but I havent seen this covered anywhere.
Old 09-16-2011, 09:16 PM
ger21's Avatar
Either you jog the tool down to the surface of the wood, and manually zero the Z axis at that point using the onscreen button, or wire up an auto zero plate and use an auto zero macro to do it. Read through this:
http://www.cnczone.com/forums/cnc_wo...tool_zero.html
Old 09-16-2011, 10:56 PM
Thanks thats helpful.
Need help understanding software interaction ChrisEffinSmith General CNC (Mill and Lathe) Control Software (NC) 1 11-19-2008 11:07 AM
Need Help!- POINTS el gordo Mastercam 1 10-04-2008 10:41 PM
Full control software and hardware available for a Solsylva.com CNC design jaboothtx Product Announcements & Manufacturer News 1 02-25-2007 02:04 PM
Shortest path between points? Software? jderou General CAM Discussion 2 12-22-2005 04:45 PM
