Hello everyone! I have been lurking these forums for a while now and now I think I am ready to get started. I have a rough design started in my head, but I ultimately want to detail the whole thing in a CAD program. Before I get started, I would like some advice on certain topics from people more knowledge about them than myself. This thread will also serve as my build log and a means of keeping track of materials, links, prices, etc. I will share a little background info with you all so you have a better idea of my capabilities. I have never undertaken a project of this magnitude before, nor have I any experience with woodworking or machining. What I do have going for me is theoretical knowledge. I am in the last year of a mechanical-based engineering degree (naval architecture), so I understand that lingo fairly well. Like I stated previously, I also have been lurking these forums for a while. I have picked up some CNC-specific lingo since then (ex. backlash), but I am sure I am ignorant to a lot yet. My requirements are as follows:
Based on these requirements, I have come up with some ideas on what I would like for each part of the build. Construction Materials First choice: MDF (local Home Depot or Kent ~$10/sheet) Alternative: Aluminium Angle (local Home Depot or Kent ~$5/3ft(?)) Linear Rails First Choice: Skate bearings bolted to aluminium angle, running on aluminium angle. Alternative: Skate bearings bolted to aluminium angle, running on a metal rod. (http://www.vxb.com/page/bearings/PROD/Kit239 $9.95) Power Transmission First Choice: ACME Lead Screws (2 x http://www.use-enco.com/CGI/INSRIT?P...PMAKA=328-2767 $24.90) Alternative: Allthread Rod (local home Depot or Kent) Motors, Drivers, Controller, etc First choice: A 3-axis kit from ebay (http://www.ebay.ca/itm/3-Axis-NEMA-2...#ht_6187wt_905 $184.88) Alternative: A 3-axis kit from Keling (http://www.kelinginc.net/ThreeXCNCPackage.html $379) Thoughts on the above would be appreciated, but I am more concerned with a few other issues. First, if I use MDF, what is the best way to make joins? Cross dowels seem to be the most obvious choice to me, but Enco does not seem to carry them. Since I will (most likely) be ordering ACME lead screws from them and I do not want to place multiple online orders, this eliminates cross dowels from the running. Although, I am intrigued by what I have seen here: Step 2: Making the Connection, joint and would like to know if anyone can recommend that sort of join. Second, I would like this CNC machine to be able to machine parts for my next CNC machine. Since my next one will likely be made from aluminium, I would prefer if this machine could handle that. Is this reasonable? Third, metric vs standard? Given that I live in Canada, I obviously follow the metric system. However, cheap bolts, MDF sheets, aluminium angle, acme lead screws, etc are all imperial. Since I prefer not to mix and match (or convert everything to metric), I will probably just stick with imperial. Thoughts? I'm sure I have countless more questions running around in the back of my mind, but these seem to be what is stopping me from finalizing a design. Last edited by floodx; 09-16-2011 at 03:15 PM. |
Being here in the US, I'm partial to Imperial measurements, but it really doesn't matter as your controller software can switch back and forth. Also, over here, metric nuts, bolts, etc. are very expensive relatively. As far as milling aluminum, there are a lot here who do it with mdf machines, though it comes at a cost of speed. Obviously, mdf is nowhere near as ridgid or heavy as aluminum or steel, so your cutting forces have to be kept relatively low; meaning you should use the most powerful spindle you could afford. You might have to add additional reinforcements or double-up here and there. It might also be better to use clear framing lumber where you think you need a larger cross section. As for your linear rail system, I think using round rails would be the most fiorgiving and easier to adjust, after experimenting with other configuratiions (flat bar, angle rails). I used the Solsyva.com plans for my first machine, and it worked out well. Even if you don't buy the plans you could get some ideas howhis machines are put together. |
You might be interested in reading the following thread, if you haven't already: http://www.cnczone.com/forums/genera...y_chinese.html |
| I have built a few machine now, so I can add a little bit to the discussion. Have you looked at these guys for controllers: eBay My World - modularcnc they are out Canada and seem to have an interesting range of products. I have a friend using one of their controllers without issue, I also have one but I haven't had the time to play with it. I usually get cross dowels from here: woodpeck.com - cross dowels, you'll pay through the nose at a depot from them. I have had mixed results with Enco for acme screws, the first set I ordered was very nice and required almost no clean up, the next batch was very rough and took a couple hours of cleaning, sanding and polishing to get to usable condition. Hope you get a good set. How much Z axis travel are you looking to have, what are you planning in using it for? I only ask since this is a place where a lot of flex can be introduced. My current machine only gives me about 2" above the spoil board, but I figured that was all I was going to need since I usually only cut .5" to 1" sheet products. All 3 of my builds have used skate bearing on drill rod (set into mdf) or gas pipe and I am happy with the results. I just purchased a box of 1000 skate bearings from VBX, so obviously I am happy with them You can see my stuff here: grumpygeek.com, I am also planing on selling kits, but I am running a little behind on my product launch: bootstrapcnc.com.Good luck with the build, if you are like most people this is just the beginning |
__________________ Anyone who says "It only goes together one way" has no imagination. |
I debated building it out of aluminum angle rather than MDF in hopes it would be sturdier. However, I ultimately decided that MDF would be easier to work with (which is important for someone with no practical experience in this sort of thing). That being said, I am considering reinforcing it with aluminum angle. I am considering doing this by bolting strips to parts that will likely flex under high loads (ex. vertically on the sides of the gantry). Hopefully some innovative designing will allow these reinforcements to act as a torsion box as well. I have done some more research into round rails and limiting their flex will make the design more complicated than I would like. With aluminum angle I can support them using the edge of the MDF (although I am not sure how to taper the edge since I will not have a router at this stage).
Speaking of which, can I get parts from Fastenal sent to a local Fastenal store and avoid shipping costs altogether?
Thanks for the link to your site. It looks like a great resource for someone such as myself.
| New Machine Build- First build from scratch | Sockles | DIY-CNC Router Table Machines | 7 | 08-23-2011 05:29 PM |
| CNC Lathe from Scratch | mackeym | Vertical Mill, Lathe Project Log | 85 | 06-01-2010 06:20 PM |
| Newbie- Starting from scratch | Superduper2010 | DIY-CNC Router Table Machines | 15 | 03-26-2010 08:52 PM |
| Learning from scratch | Kitch02 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 03-22-2005 06:00 AM |
| Scratch Design Questions | danowar | DIY-CNC Router Table Machines | 7 | 12-30-2003 04:16 PM |
