I just finished my cnc router build and i'm having a problem. any help offered would be appreciated. when I run a program in mach 3 it does not return to zero when the program is finished. it is loosing steps in both the x and y directions. I set up a dial gauge and moved the x axis .01 the axis moved about .009 +/_.0005 and when I jog back .01 it moves .01. if I jog back and forth at .01 steps the dial gauge slowly creeps .001 around for for every jog. I don't seem to have much back lash and I would assume it would show up both directions. from what I've read so far this maybe noise in the signal. I do have my 24v power supply located in the same box as my break outboard. I did try moving it out side the box but I still had the same problem. any suggestions would be greatly appreciated. . |
| Alan
__________________ http://www.alansmachineworks.com |
| Do your stepper motor couplings have a grub screw which is tightened down onto a flat spot on the stepper shaft? Likewise on the couplings to leadscrew shafts? If you have those couplings that just clamp around a round shaft they are probably slipping. |
You don't mention what kid of drive mechanism you are using (threaded rod, ACME screw, ballscrew, rack & pinion, belt drive)... maybe a pic or two of your machine could help greatly.... |
Sorry about not providing enough info. I'll try to lay it all out. I was going to do a build thread but just haven't had time to write it up and post it. I run Mach3 and I have tried using the backlash comp. to no avail. I would say the backlash is under .001" it actually takes 16 moves before I'm off exactly .010" but it only shows up one direction. on to the build Three axis machine approx 48" x 48" x 12" ![]() gantry style layout with acme rod 1/2 10 5start on the x and y axis ![]() z axis was purchased from k2 cnc ![]() I have dumpster cnc anti backlash nuts The linkage from motor to rod is direct coupled through a spider with bearing support. I have bearings supporting the rod at both ends and 2 thrust bearings keeping it clamped in place on the motor mount side. ![]() ![]() I have not put grub screw through the spider links but everything is very tight and I have not witnessed any slipage here. The motors are kelig 425 oz bi polar steppers running in parallel bipolar mode on to the controller ![]() it is a five axis break out board and stepper controller I have one 24 volt 15a power supply and three 7volt 2.4 amp power supplies running everything. I do not have shielded cable from the stepper controllers to the motors it is ordered and on the way. I have checked and rechecked all mechanical connections. Everything is tight and spinning smoothly. I have tried tuning the motors a variety of ways and tried running everything very slow. NO CHANGE I have tried changing step and direction pulse timing. NO CHANGE I have tried mach3 antibacklash compensation with no difference. NO CHANGE the machine is calibrated to within a .001" meaning if I move it an inch it moves in an inch and returns an inch +/- .0005 I hope that is enough info. If you need any more let me know and I can shoot pictures of any part in particular. thanks in advance. |
#12
| Hope to get build pics up soon. |
| BMC 25 - Z Axis creep when servos off. | gthlm | HURCO | 3 | 11-29-2010 05:56 PM |
| Newbie- Stepper motor creep | Malkaelan | Stepper Motors and Drives | 3 | 09-11-2008 07:51 AM |
| Fanuc 0M axis creep | malaron | Fanuc | 2 | 12-10-2007 09:18 AM |
| Help! Calibration Creep | johnlew | Mach Mill | 9 | 01-16-2007 01:23 PM |
| dremmel collet creep | project5k | DIY-CNC Router Table Machines | 11 | 10-18-2006 08:35 AM |
