Old 10-02-2005, 04:32 PM
walter's Avatar
Gold Member
walter is on a distinguished road
4th axis- planetary vs harmonic?
I`m interested in adding rotary 4th axis to DIY-CNC Router Table Machine.
Some people use planetary gearhead for that purpose, others claim harmonic drive is better because it`s zero backlash. Has anyone here had any experience with harmonic drives?
Old 10-02-2005, 08:50 PM
Evodyne's Avatar
Evodyne is on a distinguished road
Walter,
Hi! There are a few discussions about this going on right now-look at some of the 5-axis threads. Personally I plan to use the harmonic drives-for exactly the reason you meantion. I suppose it really depends on what you are planning on making (required tolerances, etc.) on the one hand and cost on the other. At any rate, take a peek at the other threads-it may help. Good luck!
Lance
Old 10-02-2005, 08:59 PM
walter's Avatar
Gold Member
Thanks Evodyne, good info.
I read about harmonic drive accuracy and low backlash. I`m a bit concerned about longevity... Some estimastes say 3000 hrs vs 30000 hrs with planetary gear based systems. Seems like a big difference, harmonic drives are not cheap..
Old 10-02-2005, 09:27 PM
Evodyne's Avatar
I read about harmonic drive accuracy and low backlash. I`m a bit concerned about longevity... Some estimastes say 3000 hrs vs 30000 hrs with planetary gear based systems. Seems like a big diffefence, harmonic drives are not cheap..
You may want to look at Harmonic Drive Technology's site for more info on expected life.
Lance
Old 10-02-2005, 10:46 PM
walter's Avatar
Gold Member
Yeah... They mention the 3000 hrs number too. And say that actual life would be 5 times longer. Not bad.
By the way, Evodyne. Do you have any good harmonic drive source?
