Hi All, I'm in new CNC project. This time with steel base ( X and Y axis from steel, Z axis from aluminum) Base will be welded from 80 x 80 x 5 mm (3.15" x 3.15" x 0.2") tubes. Y axis (1400mm or 55") wil be from 140 x 80 x 5mm (5,5" x 3,15" x 0,2"). Overall dimensions 1600 x 1400 x 300 mm (63" x 55" x 15"). For X and Y axis travel I plan to use Ahrens (aka. cncrouterparts) R&P system. Hiwin HGR20 Profile Rail will be used for linear gear for all axis. But, I was wondering what stepers I need to use nema 23 (3Nm) or nema 34 (8.6 Nm). I cant imagine what force will be needed for steel frame. From that choice depends other electronics choose. Here few early design renders: ![]() ![]() Thanks for any advice ! Last edited by ger21; 12-30-2011 at 03:37 PM. |
| Hi Tadas, I'm new to the cnc scene as well, so I'll leave it to a more experienced member to comment on the question about the type of stepper for this load. I'm curious about your choice of steel for the X-Axis - any reason why you are not using aluminimum as this will add significant weight? Regards, Richard |
| cnc3678 reason of choice metal tube instead aluminum plate is because all structure will be welded (to get rid of any bolts and nuts on main structure). Looking in weight - aluminum weight about 54 kilos on square meter. So on X axis would be about 30 kilos (if take 20mm thickness aluminum). Metal tube weight's about 27 Kilos. Attaching some updated Z axis design. I'm new to pulleys - NEMA23 motor with 20 teeth and other pulley is 40 teeth. So reduction will be 2:1 ? And maybe someone can help with electronics: What about this setup:
T.M. |
| like cnc3678, i too am new on this scene. but i have one question, why welding? i had some steel frames built (welded) for me, and i always found, no matter how well it was welded and/or built, it (the frame) has absolutely never been totally accurate. with larger frames, the loss was up to several milimetres, even 6 or 7mm sometimes. for me it was not crucial, as it was merely for a stand, or a makeshift table, but for something like a CNC, that needs accuracy... please, don't think i am being a smarta$$, i'm just asking. and if i'm wrong, by all means, tell me |
| lamesh99, welding can be accurate. I'm not welder, but my friend has a welding company. They have "zero assembly table", that means they assembles (by welding only one dot where needed) on that table and makes adjustments as needed and than welds permanently. But sure, they cannot be 0.001 accurate. that's because I'm using 5mm thick tubes - the steel tubes can be grind'ed to be very accurate. cnc3678 HiWin rails price's. Attaching updated Z axis pic's. For spindle motor I will use this What about backlash for R&P ? is there 0 backlash or I misunderstood something about R&P ? Can anybody help with stepper choice ? Does my choice - nema23 stepper is good ? is it powerful enough to drive this design ? I really need to know - I need to order parts. THANX ! |
Move the uprights on your gantry back. This would also better balance your gantry where most of the weight is currently on the front bearings. |
| What is the target Z range? It looks like the gantry is extended very high, and the Z plate extends way down from the gantry beam to compensate. If this is correct, both extensions add flex. Most folks here have 5"-6" of Z motion for woodworking, and could probably survive with less. |
#10
| you will learn that having the base larger than the cutting area is a good idea to clamp big jobs.
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
#11
| New Machine Build- LVL or Steel base?? | bobmagnuson | DIY-CNC Router Table Machines | 104 | 04-23-2012 08:05 PM |
| X2's Y-Axis base extension? | vcatalasan | Benchtop Machines | 4 | 08-24-2011 09:13 PM |
| Newbie- 3 axis, spinning base? | JD_Mortal | DIY-CNC Router Table Machines | 2 | 11-11-2010 12:44 AM |
| Granite or steel surface plate for machine base? | will gilmore | Vertical Mill, Lathe Project Log | 18 | 02-06-2008 09:12 PM |
| Z Axis Pedestal Base Problem | bohica | Industrial Hobbies (Support forum) | 4 | 12-15-2006 07:55 AM |
