Old 09-05-2011, 10:25 PM
rooftoplounge is on a distinguished road
Can Lego Mindstorms block run a "real" CNC?
I've seen the Lego CNC on Youtube, but I was wondering if you can use the NXT block to run a larger CNC or 4'x8' router? I'm researching a bit and looking at different possibilities.
If you could use it, what would be the advantages/ disadvantages? Thanks all.
Old 09-05-2011, 10:35 PM
judleroy's Avatar
judleroy is on a distinguished road
Although the mindstorms would be great for some real world robotic applications Cnc is not one of them. The small Cnc machines on YouTube are about the best I can see you getting for that type of application. They do not provide the correct interface or enough motor power. Check out the gecko g540. It is in the same price range and is a much better solution.
Judleroy
Old 09-06-2011, 02:26 AM
jm82792 is on a distinguished road
Arduino can work too, but in the end a real controller and drivers win.
Old 10-11-2011, 09:32 PM
Mindstorms driver
Thanks guys for the answers and suggestions. I'm looking to get the Blackfoot 4'x8' router as it looks to be the best bang for the buck (unless there's something better). I know I could build it myself but I'm not looking to spend the time building it but more time making stuff with it.
Thanks again!
Old 10-12-2011, 11:00 AM
ger21's Avatar
Look at the Joe's 4x4 Hybrid (it can be expanded to 4x8) Welcome to Joe'sCNC.com
It might be a little more money, but it's a far better machine than the blackfoot.
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Lego CNC update (the real thing) jwstolk Industrial Hobbies (Support forum) 3 09-10-2006 04:20 PM
LEGO BLOCK Cnc Router vladdy DIY-CNC Router Table Machines 15 12-10-2005 08:30 AM
First Part Cut on a real "Cheap CNC"! paulried DIY-CNC Router Table Machines 1 05-09-2003 11:44 PM
