Hi, My original plan was to use 100*50mm*5mm box section for the x axis rails. I am now thinking that using I beam section is the way to go ? I think it will deflect a lot less and provide more material for milling on the surface 102 X 44 X 7KG S275JR - Rolled Steel Joist - ParkerSteel Thoughts ? |
| I would have thought that the rectangular tube would be about 2x stronger : the height and thickness of your I beam vertical are about the same as the tube, yet the tube has two vertical walls instead of 1. Most of the strength against deflection comes from the vertical sections. Of course, it is easier to use nut/bolt combinations on the I-beam, but with 5 mm thick material you can tap either case. I don't know if the manufacturing tolerances for straightness are different for the two sections If you want to contain a lead screw inside the axis itself, C-channel might be an alternative. Check out the engineering calculator websites; they post the std formulas, and it is easy to calculate the moments of inertia of each section. Some of them have formulas adapted for the specific sections too. If the X rail is supported along its length I don't think strength will be a serious problem, regardless of what shape you use. |
| The closed tube would be torsionally stiffer than an I beam as well. I'm not sure exactly how much this would increase the stiffness of your frame, but it couldn't hurt.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| Thanks |
| 100x50x5RHS (box section) - 10.3kg per m Ixx = 1.53x10^6mm^4 Iyy = 0.511x10^6mm^4 Zx = 30.6x10^3mm^3 102x44x7RSJ Ixx = 1.53x10^6mm^4 Iyy = 0.078x10^6mm^4 Zx = 35.4x10^3mm^3 Ixx - simply put, the resistance to deflection in the direction of the major axis (up and down) Iyy - resistance to deflection in the direction of the minor axis (side to side) Zx - Strength, or how much load it can take before failing So the 2 members have the same Ixx value so will deflect the same amount for a given load, the RSJ is ultimately stronger ie. can take more load before failing (if adequately restrained) and the box section has far greater resistance to deflection side to side (over 6 times). The box section is also considerably heavier per m. The side to side strength won't matter if it is held from moving sideways by the table. |
#10
| If we're talking about a gantry beam, Iyy would normally be in the plane of the table, so for example if you cut something, you would have a force trying to bend the gantry beam in the x/y plane which Iyy would come into play with resisting. Ixx would resist vertical forces due to drilling. In reality of course it is more complicated due to the forces being applied at a distance from the center of the beam. In any case, I don't think your statement that Iyy won't matter is accurate if I understand how you're setting up your coordinate system correctly.
#12
Cheers! |
| Lite Steel Beam | rocketflier | DIY-CNC Router Table Machines | 2 | 08-06-2011 03:11 AM |
| Need Help!- How align IR beam (co2) with visible beam (red dot laser) ? | etienne delcuve | Laser Engraving & Cutting Machines | 7 | 02-04-2009 05:41 AM |
| Buying 1-axis table, steel duty | DrStein99 | Linear and Rotary Motion | 3 | 08-20-2007 08:13 AM |
| Z axis beam coupling help | Chamm128 | K2CNC | 1 | 06-05-2007 04:38 AM |
| Short beam/Long beam? - Basic design | Pat2000 | Mechanical Calculations/Engineering Design | 5 | 11-09-2005 10:49 PM |
