I built a JGRO but I'm having a problem with the size of the parts that I'm cutting. I've thought about this for a long time and I have no idea what is wrong. Some background info: Aspire to create tool paths, outputting using Mach3 post processor Mach3 to run the g-code 1/2-10 acme screws, all axes I have probotix bi-polar drivers PacSci bi-polar motors The steps per inch are all the same, (1600 or 16000, I can't remember, running 1/8 microstep either way) If you need any more info let me know! I created an extremely simple program to cut an ID and an OD. Both were drawn to 2 inches in diameter. I'm using a 1/4" router bit. For this program I roughed the diameters leaving 0.050 (on the radius) and then went back and did a finish pass. In Aspire I used the profile command for both circles. The ID is coming out undersize and the OD is oversize. If there was an incorrect setting or something I would expect them both to be small or both to be large, not one large and one small. Both the ID and OD should be 2.000 inches. The ID comes in at 1.960 and the OD measures 2.045. Both of these features were cut during the same program and with the same tool! Here's the kicker, the slots left from the router bit are exactly what they should be: 0.300 inch (remember I used a 0.250 bit and left 0.050 during the rough cut. I want these features to come out the same size! I need some help badly! Last edited by bremerr; 08-27-2011 at 10:04 PM. Reason: Add more info |
| Is this happening with just 'this file' or could it possibly be happening with all files but you just now noticed it? Are you 'sure' that your 'steps per inch' settings are 'perfectly' correct in Mach 3? Also, have you checked 'roundness' (ie, is it off the same amount in X and Y)?
__________________ http://www.cnczone.com/forums/cnc_wood_router_project_log/124543-mountaincrafts_router_plasma_build_thread.html |
| Also, try cutting some squares and measuring those. You may have to adjust your steps/unit slightly. Another thing to try is cut in the opposite direction. Tool or machine flex may result in different sizes depending on cut direction.
| Aside from machine ridgidity, I'd check to see if your bit is truly 0.25" or maybe .02" undersize! You can test this by simply measuring the bit, or making the tool diameter .23" and regenerating the g-code. Also try running the same program on a different part of the machine, or run a matrix of 3 or so and compare the measurements. If you climb cut, the tendancy of the bit is to deflect away from the "cut line," and the opposite is true with a conventional cut. Sometimes I'll rough cut with the climb direction, and do the finish pass in the conventional direction. |
| ID Cut - X Direction 1.960 - Y Direction 1.945 OD Cut - X Direction 2.045 - Y Direction 2.040 Last edited by bremerr; 08-28-2011 at 10:21 AM. Reason: formating |
| I use V-Carve Pro, not Aspire, but I don't understand the use of a Profile to give anything but the width of the cutter. Did you manually do this? The errors are very close to the 0.050 'finish pass' that you mention. On the smaller disk there is a slight notch on the top of the circle; the large circle may have a flat in the same spot. Is this a ramp in or perhaps evidence of flex/backlash? If you make the patterns exactly twice as large, do the errors scale as well? If not, I would suspect machine flexibility. If so, it looks like steps per inch entries need to be revised. |
make a change, and measure the difference... make another change, measure the difference.. and so on... Other than the tool diameter Louie mentioned, that's the 'easiest' fix (if that's the problem).. but if you're noticing it with other files/tools too, then it's probably not a tool diameter issue..
| Re-reading your original post, I would try just cutting the circles again without messing with a rough pass and finish pass.. because your dimensions are off about the same amount as this rough/finish difference.. Just cut a 2" circle outside the line with the 1/4" bit (set to .250 diameter in the tool settings), and another inside the line with the same tool setting.. and then measure it.... see if it's any better... Because it's acting like it sees the tool as being about .30" in diameter... which is the .050 you added for the rough/finish thing.. My guess is that you have something set up in Aspire and it's doing exactly what you're telling it to...
| You could always see what your g code says. If it has the correct commands in it, you know that it's your bit, something in your controller setup, or something on your machine.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
#10
| There was no rough cuts, just one pass with a 0.250 spiral upcut bit. ![]() I'm thinking of adjusting the bit size in Aspire to 0.260 and running the program again to see where I'm at. If anyone else has any other feedback, that would be great. . . |
#11
| Man, from looking at that, I'd say you have one of two issues going on... The first issue, is that something in your machine is 'loose' allowing it to move from where it's supposed to be... the fact that one of the cuts you measured varies in width from one end to the other makes me think that either your router (or bit) has a lot of run out, or the machine is 'flexing/moving as it cuts... The other possibility is that you're losing steps.. and this seems like the most likely to me from those pictures.. The problem is on 'one' axis only, and gets worse from when you started the top square to when you finished the last square on the bottom... It looks to me, like your gantry is racking and gets worse as the project goes on... I had a similar problem, and it was because one of my X axis motors was losing steps.. So a couple questions.. Were those cuts made in order from top to bottom? Was the machine homed/zeroed between cutting each of the squares? Were the squares all cut in a single pass for each? Describe your machine.. Do any axis' have dual drive? Also, in the picture is 'X' from left to right, and 'Y' up and down? Home and zero your machine, then measure the distance of your gantry to the far end of each of your rails.. Then run the program again (the longer the program the better)... then when finished, without any homing or zeroing, measure the gantry to the end of each rail again and see if they're the same as the original measurements or have they changed and how much...
#12
1. The squares were cut from bottom to top. 2. There was only one file that cut all three squares, sequentially from bottom to top, using the same bit. There were no stops from start to finish. 3. Yes, one pass per square. 4. It's a basic JGRO, one motor/lead screw per axis. See photo below. 5. In relation to the photo with the squares, X is left to right, Y is up and down. |
| Build Thread- Coming Soon -- CNC Router Parts 4x4 and 4x8 kits and plans | ahren | Open Source CNC Machine Designs | 283 | 04-22-2012 11:20 AM |
| Holes not coming out correct size | dwessels | Benchtop Machines | 21 | 11-28-2011 11:36 AM |
| Wrong Ballscrew Size? | ozzie34231 | Linear and Rotary Motion | 8 | 01-04-2008 11:23 AM |
| Purchased aluminum, sent wrong size, too big, now what? | pzzamakr1980 | General Metalwork Discussion | 2 | 09-20-2007 09:54 AM |
| Help! Cuts Wrong Size | archcasings | WoodWorking | 7 | 09-29-2005 06:05 PM |
