Old 08-23-2011, 07:19 AM
boblon is on a distinguished road
Question on gas spring cylinder
I'm planning an upcoming build and want/need to compensate for the load of a rotary table I want to move vertically.
Am thinking of using a gas spring. Are they as simple as they seem, just order the length and force I need?
Is there anything I need to be aware of so I don't order the wrong thing?
I estimate the weight to be a total of around 60-70lbs.
Thanks,
BobL.
Old 08-23-2011, 08:35 AM
dfmiller is on a distinguished road
Bob,
I have never designed anything with them but there seems to be lots of information out there.
Gas lifts, props, struts, shocks & gas dampers technical information
This looked good.
Sounds like they might be just the thing.
Dave
Old 08-23-2011, 11:52 AM
79TigerPilot is on a distinguished road
A couple of things, the force is not constant though better than a real spring. You need to look at the curves on your particular gas spring to know how it will work for you. In reading up, I found a note indicating that you want to oriented them with the main body up and the push rod down. I guess this is to keep the seals wet with the internal oil.
I have two 250 pounders on the knee of my Bridgeport CNC conversion, so far they are working fine.
Craig
Old 08-24-2011, 04:05 AM
Thanks for the replies. I just wanted to make sure there wasn't something terribly wrong with the idea, or some 'feature' to really watch out for.
BobL.
Old 09-05-2011, 05:11 AM
AndrewBond is on a distinguished road
I used one to compensate for the load of a heavy Z axis, was a simpler solution than a brake, and I felt it was less prone to electro mechanical failure... They are easy to adjust by reducing the pressure of the gas.. just remember you can't put the gas back in once you have let it out...
Bondy
Name:	Photo Aug 15, 1 39 38 PM.jpg‎
Old 09-05-2011, 08:57 AM
Thanks. I think I 'might' have found one that will work. The problem is finding one that will carry the load I want WITH the range I would like (didn't happen) AND fit in the spot I want to put it.
Two out of three was easy.
BobL.
Old 09-05-2011, 09:08 AM
You can make your own using a small air cylinder and a little pressure tank. This way you can tune it to the exact load you want to support, and adjust this during use. You can also get practically the same force throughout the stroke if the volume of the tank is many times larger than the displacement volume of the cylinder. Which is practical because the tank can be located anywhere.
Old 09-05-2011, 09:14 AM
Ok, forgive me but I don't know much about this, but the ones I'm looking at are in the 30 dollar range (mounting hardware excluded). By 'small air cylinder' you must be talking about something different maybe?
Thanks,
BobL.
Old 09-05-2011, 09:40 AM
This type of thing:
Pneumatic cylinder - 5/16" - 3" - Bimba
This is the type of tank you can use:
Amazon.com: BE Pressure 5 Gal Portable Air Storage Tank 125psi NEW: Home Improvement Amazon.com: BE Pressure 5 Gal Portable Air Storage Tank 125psi NEW: Home Improvement
Bimba cylinders are expensive and you can probably find something cheaper but this solution will be more costly than just a simple gas spring. But it can allow you to use a cylinder that fits easily in the space available and adjust the pressure to suit the load. You do need a compressor of course.
Old 09-05-2011, 12:43 PM
Ok, I see now, Thanks.
I think I will proceed as I was going and if the concept works out but I need a better solution I will look into this more.
Thanks again,
BobL.
Spring Tension Stepper Mount Question dpaish Linear and Rotary Motion 1 01-18-2012 08:13 AM
Question -- How is a bow attached vs wire and spring vtcnc CNC Wire Foam Cutter Machines 0 04-20-2011 06:48 PM
Need help spring back question Shotout Diemaking and Diecutting 7 09-12-2010 12:10 PM
SW 07 question, invoving cylinder Craigpat Solidworks 5 09-11-2007 12:15 PM
spring washer question sendkeys General Metal Working Machines 2 07-12-2004 02:38 AM
