Each time I run this file (and others) the bit deflects (if that is the correct word?) on the first pass of a profile cut. It only appears to happen at the beginning of the cut. I have moved the starting point and that does not clear up the problem. In the attached photo, I am cutting 1/2" mdf, 80 ips, 14000 rpms, climb cut. Thoughts? |
| are you plunging in , the tool could be wandering upon the plunge and straightens itself out as to tool moves along
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| This is essentially slotting, and a cutter is climb on one side, conventional on the other side of the cut, so it's normal to see some deflection. Milling a keyway in one pass in bar stock and looking at the end of the bar will reveal that the walls are skewed, and not parallel to the axis of the spindle. In regular machining you'd come in with a tool slightly smaller, then take kiss cuts on the walls to square them up. |
| I ran the file again, this time with a 1/8" carbide downshear bit, 35 ips. It did the same thing in the exact same places. It does not do this on each profile cut in the file--only a few and it is always in the same place, and on the first pass only. The other profile cuts are perfect. I will run the file again and ramp in. Thanks for the replys! |
| Is it happening on the outside edges of your table, if so it could be racking in the gantry which would go away as you get closer to the center of the table.
__________________ If it can't be fixed with a hammer it must be an electrical problem! |
#10
#11
| It is not happening on the outside edges of the table. I ran it again, this time changing the starting point to the x axis. It fixed all but one, where it just moved the deflection area to the new starting point. (At least it's consistent...) I have looked at the G code on the screen and did not see any variation in the coordinates on the start of each pass. We also made sure the table is level/square--it is. I will try a radiused lead-in. I am stumped. |
| Dust on rails causing chatter? | Hyrum R | DIY-CNC Router Table Machines | 20 | 05-16-2010 06:42 PM |
| Wobbly spindle, what's causing it please? | ImanCarrot | Bridgeport and Hardinge Mills | 6 | 03-10-2010 03:45 AM |
| What is causing this? | cxixer | WoodWorking | 31 | 06-11-2008 02:05 AM |
| VFD causing issues | Smackre | General Electronics Discussion | 7 | 11-22-2006 07:26 AM |
| Welding causing hardened metal? | InsaneEPP | Welding, Brazing, Soldering, Sealing | 9 | 11-24-2004 10:35 AM |
