Old 08-22-2011, 03:21 AM
jaru-eri is on a distinguished road
USB to parallel adapter? Will that work?
Will an usb to parallel adapter be good enough for cnc operation, or do I need an extra card in a computer without the old printer cable connection?
Old 08-22-2011, 03:39 AM
jeffrey001 is on a distinguished road
For Mach3, no, this will not work, if you want a second parallel port, buy a PCI card.
Jeff
Old 08-22-2011, 03:49 AM
Fish4Fun is on a distinguished road
USB to Parallel adapters lack the timing requisite to run steppers reliably. Best thing to do is look for an old machine with a parallel port. Typically older machines are cheap and easy to locate. Vista and Win7 don't play nice even with a dedicated parallel port, XP or 2K are much easier to get working with Mach3. The specs on the PC are truly minimal.
Good Luck!
Fish
Parallel port adapter help. Rocco85 DIY-CNC Router Table Machines 17 03-13-2010 04:12 PM
Can't get parallel card to work MechanoMan Machines running Mach Software 0 12-30-2008 05:13 PM
ExpressCard Parallel adapter? GMTool General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2008 11:41 PM
Parallel Port Adapter? bcnc Syil Products 6 03-24-2008 11:36 PM
usb to parallel port adapter mmech General Electronics Discussion 39 03-09-2006 01:58 AM
