Old 08-20-2011, 03:09 PM
forseral is on a distinguished road
Dual x-axis strange issue
Hello All,
I've built a dual x-axis machine and I'm running emc2. I'm using the keiling kit with the gecko 540 and 387oz-in motors.
I've mapped the output of the x-axis to the a-axis in emc's config. I'm finding when I advance the axis, one side advances a smidge (~.5") further than the other. As a quick test I switched the output from the g540 on the motors but same axis continued to advance further.
I realize this is not a lot to go on but I figured it was worth asking.
Anyone have any thoughts?
Old 08-20-2011, 03:17 PM
Al_The_Man's Avatar
If you have eliminated the electrical/electronic possibilities then it comes down to mechanical, No?
.5" is a bit more than a 'Smidge' in my book!
Old 08-20-2011, 03:33 PM
ha, ya, i suppose im a little delusional
Old 08-20-2011, 04:08 PM
CarveOne is on a distinguished road
Here are the EMC2 (8.04) Configuration Wizard settings that I use. Make sure that the Steps Per settings are exactly alike for both X axis motors. I don't remember if they have individual settings or assume that for the second X motor.
CarveOne
Name:	Screenshot-EMC2 Stepper Mill Configuration.png‎
ID:	140488   Click image for larger version
Name:	Screenshot-EMC2 Stepper Mill Configuration-2.png‎
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 08-20-2011, 04:16 PM
doorknob's Avatar
doorknob is on a distinguished road
Over what distance of movement do you see the discrepancy?
Are you using ballscrews or acme screws to drive the axis? Are you absolutely sure that the pitch of each screw is identical to the other? Can you test that manually?
Old 08-20-2011, 05:17 PM
I'm use 1/2-8 (8start) acme screws from mcmaster-carr. I ordered both at the same time and have validated they're the same.
I see the discrepancy in under 12 inches of movement
Old 08-20-2011, 05:59 PM
CarveOne
are you using your Y axis for your secondary X motor? I'm using the A-axis and i'm curious the gecko treats it "secondary" so-to-speak.
Old 08-20-2011, 08:54 PM
Both X motors are moving the gantry. The Y motor moves the Z assembly along the gantry.
EMC2 is using the XYZ gantry machine configuration. I never could get the XYZA configuration to synchronize the two X axis motors (X and A). I also found it difficult to find out how to get it working online. None of the descriptions I found gave anything but vague information. When you configure the wizard it will initially show four motor options. After you define X, Y, and Z motors and go to the next page of the wizard you won't see but three motor entries if you go back to that page. If you define four motors the first time they will still be there when you go back later. Weirdness. I haven't seen what later releases of EMC2 have on these pages so I don't know if there have been changes to make this slaving setup more obvious.
CarveOne
CarveOne
Old 08-20-2011, 09:15 PM
CarveOne
Odd, I dont quite understand how yours is working. Can you post your .hal file?
I configured mine manually by editing my .hal file after a basic config. Notice the bottom section highlighted in green. I appended the output pins for my A axis to the xstep and xdir commands.
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net xstep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
setp parport.0.pin-09-out-invert 1
net xdir => parport.0.pin-09-out
Old 08-21-2011, 04:24 AM
When I first run the wizard, there are the four entries. Slaving only works when the first two entries are used for the two X axis motors. They must be named X and X. X and A did not work. I found a reference to it somewhere that finally gave me the clue. I assume that both X motor entries get the same signals. It wasn't at all intuitive as to how to do this. I know nothing about messing around in the hal files.
I'll fire up the machine today and copy the .hal file for posting here.
CarveOne
CarveOne
  #11   Ban this user!
Old 08-21-2011, 07:06 AM
Here is the .hal file for my big machine that uses dual r&p drives on the X axis to move the gantry. It has been renamed to .txt file extension for uploading.
CarveOne
CarveOne
  #12   Ban this user!
Old 08-22-2011, 11:12 PM
CarveOne
Thanks a lot. as I suspected, your configuration uses the X&Y axis. what controller are you using, a gecko? reading your configuration made me realize I need to revisit my hold timings and such. I guess could be losing steps on motor?
i did some additional testing tonight and found 2 strange things:
first: I did some additional testing today and noticed a few strange things: When I dropped my IPM to 1ipm, the gantry stayed aligned. jogging at high speeds caused it to become out of square.
second (off topic) When i ran the gantry from 0 to 20" back and forth without pause, the gantry would not make it to the 0 and 20" position until the last
Tags
dual x-axis
strange emco 325 issue ratedr EMCO Lathe 0 08-09-2011 08:25 AM
Strange issue with a C10 BOB Brass_Machine Automation Technology Products 1 04-26-2011 06:32 PM
Dual Steppers or Timing Belt for Dual X-axis? GEBrown Linear and Rotary Motion 3 05-27-2010 11:45 AM
Strange MAzatrol / EIA-ISO issue SPE_user1 Mazak, Mitsubishi, Mazatrol 3 09-09-2008 08:10 AM
Strange serial comms issue TLSupper Machine Problems, Solutions , Wireless DNC, serial port 2 09-27-2007 01:00 PM
