Old 08-20-2011, 03:06 PM
nat45928 is on a distinguished road
CNC spindle motor questions
Im putting together a Zen toolworks 12x12 CNC but i need a spindle motor, i thought about using a dremel but i dont think it will cut very well. I would get the spindle from zen but i would rather get a brushless one so i dont have to worry about replacing them down the road. DO you have any suggestions on what to get and where i can get a good quality set of end mills?
im planning on cutting wood, wax, and plastic. I might try and see if it will handle light metal though.
Thanks,
nat
Old 08-21-2011, 01:03 PM
Pplug's Avatar
Pplug is on a distinguished road
try an 800watt chinese spindle & vfd off of ebay or you could look for a Kress.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 08-21-2011, 05:21 PM
the kress spindles look nice and would be great but thats a little more than id like to spend, its there a router that you would suggest?
Old 08-21-2011, 05:24 PM
Pplug's Avatar
I use a hitatchi 12vc that is quiet but it is large for your machine and has 2.5 hp.
Old 08-21-2011, 05:31 PM
Yeah, i saw that and thought to it might be a little big..... I guess ill stick with a dremel for now and pick up something better later down the line.
Old 08-21-2011, 05:52 PM
dfmiller is on a distinguished road
Have you looked at any spindles from Wolfgang Engineering?
Home
I have not got one yet but it looks very nice.
I am liking my 2.2 KW Water cooled Chinese spindle.
From what I understand the Dremel spindles suffer from several weaknesses. Bearings and run-out are two that spring to mind.
Dave
Old 08-21-2011, 06:26 PM
Hummm.... i do like that, do you know of any way to get in contact with him?
Old 08-21-2011, 07:00 PM
What do you think of using this:
PR10E 1 HP Electronic Palm Router-PR10E at The Home Depot
Old 08-21-2011, 07:19 PM
louieatienza is on a distinguished road
He sells his stuff on eBay, look for wolfgang314 or something like that...
Old 08-21-2011, 07:28 PM
alright ill look, what do you think about that bosch?
  #11   Ban this user!
Old 08-21-2011, 07:32 PM
A lot of folks use them here with success, and they're relatively cheap and easily found. Better yet, you can get precision collets for them at PreciseBits.com. I use one on the jobsite, for quickie trim and routing jobs (like door installations) but never mounted it to my table...
  #12   Ban this user!
Old 08-21-2011, 08:20 PM
alright, i think im going to go with that. Ill get the BOPG-COLT-8KIT (Precision Bosch-Colt Compatible Nuts and Collets) to use instead of the 1/4" one that comes from bosch. What would you recommend end mill wise?
X3 Spindle/Motor upgrade questions. hab82 Benchtop Machines 11 10-13-2009 04:40 AM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Questions about Fanuc spindle DC motor Jonne Fanuc 2 11-09-2007 07:54 AM
Boss spindle motor wiring questions moto21 Bridgeport and Hardinge Mills 11 03-29-2006 10:13 PM
Spindle Motor Questions? Willyb Haas Mills 5 02-08-2006 12:07 AM
