Old 08-14-2011, 06:42 PM
microcarve is on a distinguished road
microcarve MV2 plans & files
I get asked about plans...very often.
So, I've decided to make my files and techniques available to
anyone who'd like to make their own machine.
The MV2 version of several machines that I make as been refined
and tweaked to a point where I don't think it can be any better.
But someone may do just that and I'd like to help them along as
best I can.....
I'll begin by making the dxf files available for the very few MDF parts
that are left in the basic design....starting with the large side panels.
Most other parts are relatively inexpensive to buy and I'll make
my sources available as well.
Some parts may be too complex and I'll also make those parts for
sale, but someone can save some considerable $$ by sourcing stuff
like extrusions, rails, bolts, acme, threaded rod....etc...etc...
The MV2 machine is a small desktop sized machine that I personally
find I need and use more often than my larger machine. There are
many great advantages to the small desktop machine.
One...it's less expensive to make....obviously....
With the cold weather coming before long, a desktop machine allows
for doing projects in comfort indoors.
It's the ideal type of machine for newbies. CNC can get to be a very
expensive hobby and many people make large investments and find
they have little time to make use of them. A smaller machine allows for
learning in comfort and at a pace when our limited time is available.
Software alone is where many get "stuck". Getting a mechanical machine
in place and the needed electronics is usually the easy part. Software
can take some time and what's learned by practice/experimentation
with the small machine applies to the large machine....if/when someone
may see they need a big machine.
A small machine is portable. It's easily moved...and importantly...enclosed.
The MV2 isn't a toy machine that uses little Nema 17 motors. It's a very
viable light commercial duty machine. It's designed from the start to
use the relatively powerful trim router such as the Bosch Colt.
The recommended electronics packages and motors are the exact same
ones that run some large machines. Surely smaller electronics kits and
motors will run the machine fine, but for little more $$ than they cost, the
better kits are the smarter purchase. That stuff is easily resold if someone
were to decide that cnc isn't for them....and ...is easily transferred and
fully adequate for any future larger machine.
There are parts that may be too much trouble or time consuming for
many of us.....the Z axis for example. I'll make those sort of parts
available for sale. But...the dimensions and materials list will be made
available for those many of us who can make them. It's all very simple
dimensions and sizes. The machine has been as simplified as I can
get it.
Having built many-many machines over the years, I believe the MV2
is a premium desktop machine. It's rock solid and extremely reliable.
But, it's a fairly expensive and time consuming machine for me to
produce very many of them. That mostly has to do with time and
my insistence of test fitting every single aspect and part.
By making all the information readily available, hopefully many will
be able to take their time and build/assemble one for much less than
I could afford to sell the machine for.
If there's any interest, I'll make more files available along. I build machines
from memory so I don't have a lot of files on hand, but the thing that
makes building from memory possible, its the sheer simplicity of it.
A simple list of parts and dimensions should suffice, but we'll see what's
needed or desirable.
Anyone who'll try to cut these files will know what they need to do
to make their gcode files....I'd guess...
The extrusions are 8020 #3075
Rails are 18" and 16" from McMaster.
Rail bushings are made from 1" round 6061 aluminum. Lathe turned to
fit the rails ends.
That's pretty much it for a very surprisingly strong, durable and rigid
and practically self aligning basic machine frame.
Pictures of the first MV1....which was a tiny bit smaller....
http://www.microcarve.com/zone14/mv1/index.php
Side panel dxf files.....
http://www.microcarve.com/zone14/microcarveMV2.zip
I have no idea if there's much interest...but we'll see. I do think the
MV2 design makes an extremely fine desktop machine. There's years
of $$, time, and trial & error to get it as simple as it is.
John
Old 08-14-2011, 07:30 PM
Here's the 1/4" deep pockets cut into the 3/4" MDF part.
I use a 1/4" upspiral bit to make the parts to avoid any tool changing.
pictures....
http://www.microcarve.com/zone14/mv2...des1/index.php
The 8020 extrusion has holes through it that allow 1/4" threaded rod to
fit fully through and allow the assembly to be tensioned.
That...for all practical purposes, makes everything self align and square
itself...assuming parts are carefully made square to begin with....
Tension rods have proven to be far better than bolts from my experience.
Once tensioned....it's practically unbreakable...and Very rigid.
The bearing holder inset plate is cut from 1/2" x 1.25" 6061 aluminum
extrusion. Fits perfectly in the pocketed recess and once tightened
in place, it won't shift during use of the machine.
John
Old 08-15-2011, 12:37 AM
leaveme is on a distinguished road
Wonderful, John!
I do really appreciate your sharings. Hope other parts follow...
http://liana-tech.com
___________________
Old 08-15-2011, 06:13 AM
Originally Posted by leaveme View Post
Wonderful, John!
Thanks Very Much!
The frame itself is pretty easy to see how that's done and it doesn't require
much that most anyone can't do....or have done.
The basic frame and the steel shafts are the bulk of the weight that's
been too costly to ship to many places. So with the dxf files....and the
ability to alter the steel shafts to metric measurements as needed, someone
can easily build a very nice machine.
I'll add that yes, it can easily be extended. That question comes often.
But....the longer it gets extended, the more of a general purpose machine
it'll become. Reason is, the longer extended rails only add more
potential for flexing with hard use.
That problem is simply enough solved, though, by having realistic
expectations about what any DIY machine can do. A very tightly built
machine is more likely to do higher quality and finer work if it's not
overly extended.
It's a very highly adaptable and simple design....
John
Old 08-15-2011, 09:03 AM
br1 br1 is online now
br1 is on a distinguished road
Thanks for that, it looks like a fun project, I too have made a little machine myself, so I can respect the research and development aspect of your adventure. I also like your other larger build(s) I have seen on here. Thanks for sharing.
Old 08-16-2011, 10:04 PM
Walky's Avatar
Walky is on a distinguished road
It's very nice of you to share this info, I've followed (and been inspired by) your designs for quite some time and I'm sure a lot of people will make their own MV2
Do you have an estimate of how much would you charge for one of your Z axis? I love those and I'd be nice to use them on my (gantry) machines in the future. What rail diameter do you use for the Y axis/Y carriage bearings?
Old 08-16-2011, 11:03 PM
Thanks Very Much!
John
Old 08-16-2011, 11:27 PM
Thanks!
I've been selling the Z's for $120 for the standard 4" travel and $135
for the 6" travel.
They're made with use of the Bosch Colt in mind and The 3/8" thick
aluminum plate is drilled for the Colt holder that K2cnc sells. It's
a Very Nice spindle holder that I couldn't make for what they charge for it.
A Very well made cnc machined chunk of solid aluminum....
CNC Routers, Routers for Wood, Routers for Plastic and CNC Plasma Cutter
The one they make now looks a bit different from the one on their
site. Better IMO.
Also, most all spindle holders that Probotix sells wil bolt directly in place.
They sell holders for a good range of trim routers.
CNC Router Spindles
My own Z's are very carefully machined and use 1/2" Thomson case
hardened precision rails.
They use 3/8-12 acme for leadscrews and have solid brass couplings
pre-attached with 1/4" bore for Nema 23 motors.
I made most of one today to see how long it takes. It'll take me
the better part of a day to make one. There's a lot of tool changing
and repositioning and squaring of the metal that just takes as long
as it takes. But they come out Very Nice....
There's a bunch of them in use on lots of different machines.
A Bosch Colt is a pretty powerful and well made router for the relatively
low price it costs.
A Z axis is a really important part of a machine. I've tried many many
dozens of variations and techniques and combinations of materials
over the years. I think these Z's are very well made and are
highly reliable for the long term.
John
Old 08-16-2011, 11:43 PM
The side panels with the Logo in the dxf files aren't necessary for
any structural part of the machine. I use them for cosmetic purposes
mainly....and to add a place to put a logo.
They certainly can't lessen anything if they're used, but if a machine is
extended, they get to a point where they may be beneficial to strength
and stability.
I made one machine that's a 15 x 14 cutting area for a specialty mold
making shop once and that was a case of the side panels being a good
idea.
If the files are opened in Vectric software, they should be the correct size
for creating the cutting tool paths and gcode files.
I want to add here that I do keep the rights to my work for reproducing them
for resale. If anyone wanted to reproduce the design for purposes of reselling
the machines, they can get with me to work something out.
For anyone who wants to make a few for their own personal uses...or even
gifts.....this machine is Ideal for schools or educational institutions, I'm perfectly
willing and able to help them in any way I can.
Anyone with a mill and lathe can make one very inexpensively and Will Be
impressed with the quality, strength and stability.
It's a Great and Highly useful machine....
John
Old 08-17-2011, 12:40 AM
Here's some pictures of the basic assembly of an A4.
The A4 files are a little different from the MV2. I made the MV2 available
first because most people want the best machine they can make and
the thick 8020 aluminum extrusions do add to the rigidity and strength.
They add some cost, but it's worth it for the ease of assembly and
the long term durability they add to the design.
The A4 is cheaper to make, but a little less rigid if someone wanted
to cut harder materials.
The important thing is making the parts as closely fitted as can be done
and checking them constantly....
http://www.microcarve.com/yahoo/markm/
John
  #11   Ban this user!
Old 08-17-2011, 01:04 AM
saundby is on a distinguished road
Good stuff, John!
I probably won't make an MV2 soon since I've got an A4, but the design is interesting to check out.
Your points about why to start with a smaller machine are spot-on, I feel. I'm trying out several different software "toolpaths" myself to find the best route possible from idea to product, and enjoying the waypoints as I go.
In my own case, I'm toying with the idea of using the A4 to cut frame elements for a scaled-down version that is small enough to be "luggable" along with its enclosure, motors, etc. I figure if I can get the size and weight down to something comparable to an old Osborne 1 computer, that'll be about right. I want the luggable CNC to take to my computer classes with me-I already take my old Osborne several days each year-so I figure a CNC about the same size would be no more trouble than that.
The kids get really excited watching the floppy drives in the Osborne work, imagine how much fun seeing a working (if small) CNC would be.
Of course, I'm expecting to use components as you've designed them when I get to that particular project. No sense trying to reinvent The Wheel and ending up with The Triangle instead.
http://saundby.com/ --my website
http://catsonkeyboards.blogspot.com/ --my blog
  #12   Ban this user!
Old 08-17-2011, 01:26 AM
Originally Posted by saundby View Post
Good stuff, John!
Thanks Mark!
There was one time when all I had was a bigger machine out in my shop.
The cold weather....it was winter time...made it pretty uncomfortable
to go out and use it later in the evening when I'd have my very
best ideas of something I was just dying to try out.
Then, actually turning the loud router on....I doubt the neighbors
were pleased about that....
Many of us have very limited time, so a smaller desktop sized machine is
a Very Nice thing to have available to play around with in comfort...and
in many cases, limited indoor space. And it's warmer inside in the winter
time...
Your idea for a smaller portable machine sounds Great! I think the electronics
that run everything can be pretty easily incorporated right into the design.
A lot of my own work would fit well within a 6 x 6 x 2" cutting area, so
I hope to make one like that one of these days. In fact, I have a small
one I may sell off pretty soon.....the green one here....
http://www.cnczone.com/forums/diy-cn...p_machine.html
That's a Cool little machine!
John
Build Thread- microCarve A4/Gecko G540 saundby DIY-CNC Router Table Machines 27 05-28-2011 12:30 AM
Build Thread- "MicroCarve" A-10 machine cnctoolman DIY-CNC Router Table Machines 30 01-19-2011 09:27 PM
Need Help!- How can I convert .nc files into .nci files AlphaD Fanuc 2 07-08-2009 01:45 PM
Need Help!- Convert files to Inventor files. bartL Autodesk Software (Autocad, Inventor etc) 7 02-03-2009 11:38 PM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
