Old 08-12-2011, 09:22 AM
RSIBG is on a distinguished road
axis exchange for Onsrud Router
Onsrud switches their x and y axis. Why I don't know. Is there a macro, or a way to fix this?
Old 08-14-2011, 08:28 AM
michaelthomas is on a distinguished road
I use an Onsrud, and have not experienced this. Are you saying that your origin is screwed up?
Old 08-15-2011, 06:49 AM
No. Per Onsrud, the x and y axis are switched. If you are standing in front of the machine the left and right movement is the "Y" axis.
Old 08-15-2011, 01:41 PM
DonFrambach is on a distinguished road
Could you then swap the x and y connections on your control box?
Old 08-15-2011, 02:07 PM
Phife is on a distinguished road
If he did that then all the parameters for axis length, etc. would not be correct.
Cant you just rotate the part you are working with in your CAD/CAM program to be the correct way?
Or use find/replace to swap all the X and Y values in your Gcode?
Need Help!- NEE - AMC Control on Onsrud Router MarkT Commercial CNC Wood Routers 5 04-06-2012 10:32 PM
CR Onsrud vs Thermwood CNC Router Units dgraf CNC Machining Centers 9 04-14-2011 09:41 PM
Onsrud CNC Router question CJH Commercial CNC Wood Routers 0 07-18-2008 09:07 AM
Onsrud Overhead Router marksnwv Open Source CNC Machine Designs 2 11-18-2006 11:18 AM
