Old 08-08-2011, 12:57 PM
EKFER's Avatar
EKFER is on a distinguished road
Exclamation What size motor should I use?
Hi, I need help in the selection of a nema 23 or 34 stepper motor for the machine I'm building (aluminum). The Y-Axis (20") and Z-Axis (12") will weight approximately 65 lbs total. I'll be cutting 1/4 aluminum and wood. What size motor should I use for the X-Axis (40")? Thank you
Old 08-08-2011, 02:05 PM
Al_The_Man's Avatar
http://www.kollmorgen.com/en-us/supp.../motioneering/
Need Help!- Motor size jrs591 Open Source CNC Machine Designs 1 04-02-2009 09:39 PM
Motor size beborracho DIY-CNC Router Table Machines 2 07-10-2007 09:23 AM
motor size? eloid Stepper Motors and Drives 1 03-04-2007 03:40 AM
cnc motor size jarr88 General Metal Working Machines 3 03-16-2006 12:01 AM
Motor Size PROBUILDER DIY-CNC Router Table Machines 0 04-07-2004 01:54 AM
