Old 08-07-2011, 09:50 PM
Rene Nuñez Paz is on a distinguished road
Source for a cheap spoilboard lelever bit
Hello, I need buy one cheap spoilboard leveler bit, but every one that I found is over 200 usd.
Could some one, help me to find any source for a cheap bit of this kind. I don't need a high level bit.
Sorry my bad english
Thanks in advance.
Regards
Rene
Old 08-07-2011, 10:49 PM
louieatienza is on a distinguished road
Thanks in advance.
Regards
Rene
Amana makes large straight bits, up to 1-3/4" that you can use to surface a spoilboard, and relaively cheap as well...
Old 08-08-2011, 07:37 AM
Thanks, I was looking but yet I can't find any.
Bye
Rene
Old 08-08-2011, 09:35 AM
Bye
Rene
Check here:
Bottom Cleaning Router Bits - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits
or here:
Straight Plunge Cutting Router Bits - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits
Can use them for rabbeting as well...
Old 08-08-2011, 09:52 AM
CNC Lurker's Avatar
CNC Lurker is on a distinguished road
I got this bottom cleaning bit from MLCS awhile back, and the Ø1 1/2" is on sale right now for $17:
MLCS Bottom Cleaning Router Bits
http://paul-flores.com/
Old 08-08-2011, 11:47 AM
Thanks!!!
Verey useful help!!
Bye
Rene
Old 08-08-2011, 03:35 PM
Mountaincraft is on a distinguished road
I just used a Rockler 1" mortising bit (two flute straight bit, carbide tipped).. Worked fine...
I think you can use just about any end mill style wood bit (square end), it just takes longer with smaller bits...
Unless someone can tell me different, what's the point of paying $200-300 for a spoil board surfacing bit? Unless time is just 'that' expensive for you?...
http://www.cnczone.com/forums/cnc_wood_router_project_log/124543-mountaincrafts_router_plasma_build_thread.html
Old 08-08-2011, 06:31 PM
dfmiller is on a distinguished road
Onsrud had a 1 1/4" one for 30 ish. It was the largest cheapest one I could find locally. 91-000.
I agree anything with a flat bottom should work OK. The mortising bits around here were smaller and more expensive.
Dave
Old 08-08-2011, 11:09 PM
That seems like the hot ticket fr the money...
How's it work for you?
Old 08-09-2011, 10:33 AM
CNC Lurker's Avatar
Works good, just remember to turn the router speed down to 18,000 rpm.
Name:	Freud Router Bit Speed Chart.jpg‎
Need Help!- Source for cheap stepper motors Rene Nuñez Paz DIY-CNC Router Table Machines 6 08-05-2010 08:29 PM
Source For Cheap Linear Components... hellman81 Linear and Rotary Motion 7 05-28-2009 08:02 AM
Source for cheap steppers? Chris D Stepper Motors and Drives 5 09-02-2005 07:59 AM
Need Source for Cheap PS Filter Capacitors? Bird_E General Electronics Discussion 2 02-08-2005 12:29 PM
Cheap source for G320 aconde Gecko Drives 5 11-12-2004 05:09 AM
