I'm trying to figure out the optimal distance between the bottom of my Y- axis cross member and the top of the table. Of cource the design of the Z-axis will play some part in the design. Is there a rule of thumb to follow or similar? thanks |
| I make mine high enough to clear the thickest part you'll have mounted. Imo, for a router cutting wood, that's probably about 3". But I'm making it ~5" to allow for jigs or fixtures. The lower it is, the more rigid the machine will be. Once I pick the gantry clearance, I then determine Z axis travel. I want to be able to reach the table with a bit sticking 1" out of the collet, and clear the gantry with a bit sticking out about 3". For 5" clearance, that's 4" down, and 3" up, for a Z travel of about 7". Then add 1 more inch or so for rapid clearance.
| I'm about to take my Aluminum to the machine shop to have the gantry sides made (holes drilled). I was hoping the elite here would give me some comments. I will be using 2 x THK25A bearing blocks per side. The HSR25 rail will be mounted to the lower slot of a piece of 80/20-3030. I have made sure all measurements comply with the measurements on the FLA machines as I want to use their bearing blocks with my design. The Y-Axis will be a piece of 80/20-3060. The distance from the top of the 3030 to the botom of the 3060 will be 6.75" and with a 1.5" spoil board on the 3030 the clearance will be 5.25". The Aluminum is .75" thick by 8" wide and 18.5" long. I'm drilling .3281dia clearance holes for the 5/16 bolts, is this the correct diameter? The THK25A blocks call for an 8mm bolt so I made the clearance holes .3125dia. Thanks everyone |
| New Machine Build- New design - Quick question about my design | guerd87 | DIY-CNC Router Table Machines | 1 | 02-14-2010 12:35 PM |
| Design question | AndyL | DIY-CNC Router Table Machines | 3 | 04-01-2007 03:54 PM |
| Simple Z-Axis Design Question | deleteallusers | DIY-CNC Router Table Machines | 11 | 03-29-2007 05:17 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| Carving machine,Design question? about z axis | hkxy | Laser Engraving & Cutting Machines | 3 | 10-11-2006 03:43 AM |
