Old 08-06-2011, 07:57 PM
Drools's Avatar
Drools is on a distinguished road
Parts for THK bearing blocks.
Does anyone know if parts are available to repair THK bearing blocks? There must be kits that are specific to the part...
Old 08-06-2011, 11:07 PM
louieatienza is on a distinguished road
I've actually been in contact with the THK rep in my area, and have the saem exact question. I'm going to send an email out to him....
Old 08-08-2011, 12:07 AM
Drools's Avatar
I'm not sure how many of you have taken apart a THK LM System Block so I will post some pictures of an HSR25LA stripped down. The LA versions have the same bolt pattern as the normal A version but the L stands for a longer block. I was able to repair the blocks I have using parts from other HSR25CR blocks specifically replacing the End_Caps.
I do not know the technical name for each part.
ID:	139647   Click image for larger version
ID:	139648   Click image for larger version
ID:	139649   Click image for larger version
ID:	139651   Click image for larger version
ID:	139652   Click image for larger version
ID:	139653   Click image for larger version
Old 08-09-2011, 02:56 PM
Drools's Avatar
I just want ask if anyone knows how the preload works on these blocks please fill me in.
Two of the HSR25LA blocks are marked Y7Y20 the other is marked G9A16. The markings on the two HSR25CR blocka are 3I397.
The two LA blocks marked Y7Y20 move very smoothly on the rail (very little preload) however the G9A16 block was quite difficult to move on the rail even though the bearings moved smoothly in their tracks. I would say this one had quite a bit of preload. I took the bearing out of the G9A16 and measured the balls @ 4.78mm in diameter the balls in the CR blocks are 4.75mm dia. I replaced the 4.78mm balls with the 4.75mm balls and this bearing block now moves with much less force.
Does anyone know if the end-caps are universal(pic 4 & 5 above)? On both the LA and CR blocks the end-caps are marked HSR25X or HSR25XE. I took the dust seal off a brand new HSR25B block and the end-cap is marked HSR24XE.
What other parts on these blocks are common between the models?
What grease should I be using to lub these blocks?
Need Help!- Bearing Blocks. Drools DIY-CNC Router Table Machines 27 04-01-2011 02:41 AM
Aluminum end bearing blocks woodworker2 EBAY ADS 1 04-01-2010 04:39 PM
Makeing bearing blocks FandZ DIY-CNC Router Table Machines 3 09-07-2009 10:27 AM
Skate Bearing Blocks? thebluedirt Linear and Rotary Motion 12 02-08-2009 07:59 AM
THK SSR20 Bearing Blocks wanted in UK santiniuk Europe Club House 5 03-13-2006 03:59 AM
